Removing the rubber strips from side of 3 door.....
Old Dec 27, 2003 | 04:33 PM
Darrone's Avatar
Darrone
Default Removing the rubber strips from side of 3 door.....
Hi guys,
The rubber strips that run along the side of a 3 door...what's the best way to remove these?
Are they just glued on or do they clip in to the bodywork and leave holes behind them?
Cheers!
Darrone
Old Dec 27, 2003 | 06:26 PM
TIFF's Avatar
TIFF
Chasing Radders
When i removed the ones off my Sapphire i used a wall paper scraper(was being resprayed so wasnt worried about scratching it)
They were just stuck on
But if you do take them off make sure you store them flat as the kink really easy and they are fucking expensive too
Old Dec 27, 2003 | 07:38 PM
dave cos4x4's Avatar
dave cos4x4
Bit of heat and they come off easier, hair dryer should do it!!
Dave.
Old Dec 28, 2003 | 01:54 PM
B11GNS's Avatar
B11GNS
Looks better without them, checkout my sig!!!
Old Dec 28, 2003 | 05:09 PM
Default Re: Removing the rubber strips from side of 3 door.....
Originally Posted by Darrone3dr
Hi guys,
Cheers!
Darrone
No holes in 3 dr cossie sidestrips; just glued.
Old Dec 29, 2003 | 09:08 AM
Darrone's Avatar
Darrone
Cheers lads!
Old Dec 29, 2003 | 11:21 AM
POPEYE's Avatar
POPEYE
FAIRY CAKE
imho i like mine without the rubbing strips
but you do need something a bit bling,wheel wise
otherwise they do look a bit bland on the sides
i very much bout you will be able to put the OE ones back on if you wanted to,cos of the metal inside and it never goes back right
Old Dec 29, 2003 | 05:55 PM
Switch's Avatar
Switch
what about saff ones, they the same to come off and do they look good without them?
Old Dec 29, 2003 | 06:42 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
the sapp ones are pot riveted mate,or clipped what ever you want to all it
so leaves holes behind them
Old Dec 29, 2003 | 08:13 PM
Switch's Avatar
Switch
oh well will fookin leave them on then
Old Jan 6, 2004 | 12:57 PM
Blakeya's Avatar
Blakeya
Looks better with the side strips in IMO. See my sig!!
Andy
Old Jan 6, 2004 | 10:35 PM
mk2rstaff's Avatar
mk2rstaff
i have to agree to disagree if you know what i mean i like it both ways( the strips i mean)
Old Jan 8, 2004 | 10:38 PM
RSCossieGaz's Avatar
RSCossieGaz
what a fcuking pain theres holes left on the saff ones
looks like that ideas out of the window then
Old Jan 18, 2004 | 05:40 PM
can u get non oe strips
Old Jan 18, 2004 | 06:01 PM
use a piece of twine m8, just run it under one end and use a sawing motion to get them off. it leaves the sticky on but that can be removed with a degreaser or warm water and washing liquid. and it doesnt damage your paintwork this way.
Old Jan 18, 2004 | 07:46 PM
PJay's Avatar
PJay
Without mate, they come off easy!
Old Jan 30, 2004 | 08:05 PM
Rene's Avatar
Rene
hmmm thinking about this now as well just cant decide yet white 3 dr wiv or wivout them ?
Old Feb 5, 2004 | 08:41 PM
RobCarden's Avatar
RobCarden
358bhp
OFF OFF OFF
Old Feb 18, 2004 | 09:36 PM
If you want to stick the mouldings back on all you need to do is remove the metal backing (you can never get that straight once you take them off) using a hot air gun or similar and stick them on wit some double sided trim tape.
As long as you are careful about the length (the strips can be 'adjusted' whilst warm) and use a wooden batton as guide to keep you striagt and level you'll never tell the differance froma rather expensive new set.
HTH.
Iain.
Old Mar 4, 2004 | 12:42 AM
R4N SS's Avatar
R4N SS
I prefer them on
Old Apr 12, 2004 | 12:41 AM
saphs have six holes 2 on each door and anothere two on front wing.know this as just finished welding them up and painting my saph.three doors are just glued on ,if u go to a good body shop they should be able to get stuff in an arosol tin that will soften the glue.used stuff before cant remember its name.
Old Apr 12, 2004 | 11:32 AM
I find dental floss works wonders, for removing decals and strips!
Old Apr 12, 2004 | 04:05 PM
i got my car with them all ready removed.
Old Apr 12, 2004 | 04:21 PM
Gav Diamond's Avatar
Gav Diamond
I prefer them on
Does anyone know where i can buy some from?
Gav
Old Apr 12, 2004 | 10:03 PM
gazcos's Avatar
gazcos
Hi Gav, speak to Ian3dr. I think he knows where to get these
Bailes1992
Sep 3, 2015 02:17 PM
Aug 29, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
