MFi Turbo Fuel Shut off?
Hi guys, just wondering does the RS Turbo (MFI) have a fuel 'shut off' system on the overrun like the RS1600i/XR3i's, and if so how does it work on the RS Turbo?
If you not sure what im talking about on the RSi/3i its the little shut off valve thats on the side of the metering unit induction hose which operates when you take your foot off the throttle.
Anyone?
Thanks for looking
Anyone?
Thanks for looking
RST has a overrun fuel shut off, but it's very differrently realized than in the XR3i. XR3i has a valve that opens and connect the air chambers above and below the plunger plate making it go to zero postition. RST has an electric mixture control that is been taken to full lean on overrun.
Matt Baxter
Sep 16, 2015 08:30 PM
marky_g
Aug 15, 2015 10:43 AM
