Fitting a boost gauge???
Old Oct 9, 2006 | 09:36 PM
cosrep's Avatar
cosrep
Default Fitting a boost gauge???
Ok I tee'd into the brake servo line right beside the inlet plenum and before the check valve in the line. At idle the boost gauge shows -20psi, when I rev the engine however it won't go into positive figures just goes as far as 0 as I lift off and the dump valve activates. What am I doing wrong?
Old Oct 10, 2006 | 05:12 PM
scottbrown's Avatar
scottbrown
nothing.
will only see positive while driving. if you are seeing positive at idle/ revs then u have anti lag.
at idle as long as gauge moves when revved it is working. take it out for a spin and you will see positive boost baby
Old Oct 14, 2006 | 05:47 PM
SafeChav's Avatar
SafeChav
You'll be lucky if you see a boost pressure without creating any load on the engine (driving the car)
And, im sorry to criticise but the brake servo line
Thats the one pipe i would steer well clear of, if that blows off or gets a leak while you are driving then you may end up running into the back of someone
Old Oct 15, 2006 | 01:54 PM
Ben26's Avatar
Ben26
Thats what i thought
Old Oct 18, 2006 | 10:39 PM
NEWTON's Avatar
NEWTON
servo line
Kyle Langford
27
Aug 5, 2019 07:54 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
mrmann
Aug 20, 2015 11:24 PM
no1trancefan
Ford Focus ST
Aug 7, 2015 09:21 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
