rolling road
Old Oct 9, 2006 | 12:33 AM
lewis_lisa's Avatar
lewis_lisa
Default rolling road
is it possible to have my car put on the rollers if it has some fuel probs without running the risk of damaging my engine as my car is running lean and misfiring,it also has a chapping noise at the top end which ive put down to a worn cam. the car has not been set up since oct 2004 which was at power engineering. i cant take the car back to them as am back in scotland.
the engine has had 12k spent on it and i dont want to damage it, the reason ive not tuned it yet is that i never use it unless its a nice day.
cheers lewis
put my mind at ease
Old Oct 9, 2006 | 05:05 PM
Andy_R's Avatar
Andy_R
Give Colin at AVA a bell 0141 848 5257.
Based right at the back of Glagow airport they arent a million miles away from you...they will not allow the car to run lean on the rollers and will terminate a run if its detremental to your cars health.
They are more than capable of finding/fixing the caue of your fueling issues.
Old Oct 9, 2006 | 07:49 PM
JamboRS's Avatar
JamboRS
focus rs 1672
awrite lewis,as andy says give them a phone
have you fitted the new cam,as i would fit that then get it in to get set up,there £60 an hour on the rollers but most dont need more than 1 hr,though i have seen my car on there for several
Old Oct 10, 2006 | 10:18 AM
JohnW's Avatar
JohnW
As mentioned above, the rolling road operator won't run the car if its running excessively lean etc.
I'd be slightly concerned about the noise at top end, if it's running lean you sure its not det'ing? If so avoid running it hard else it'll destroy a piston.
Old Oct 12, 2006 | 12:37 AM
lewis_lisa's Avatar
lewis_lisa
cheers folks that is a worry of my mind, its taken me so long to find a good 1 so i dont want to wreck it.
im still not sure what the rattle at top end but seems to go away when the engine is revved higher.
boeb
Jan 9, 2020 05:11 AM
mk22door
23
Oct 2, 2015 10:06 PM
AJC
Oct 1, 2015 06:47 PM
Mikersturbo
Sep 27, 2015 07:43 PM
