Oil Capacity
Old Oct 7, 2006 | 04:11 PM
C0S_TURBO's Avatar
C0S_TURBO
Default Oil Capacity
Hi, I have taken the engine out of my 2wd Saph and put it in a 1964 105e Anglia. I have had to use a MK II RS2000 sump for clearance, but this has meant I can only get just over 3 litres of oil in it. How can I increase the oil capacity? Am I able to fit a larger oil filter, oil cooler or some kind of reserve?
Many thanks in advance!
Old Oct 13, 2006 | 01:25 PM
C0S_TURBO's Avatar
C0S_TURBO
Anyone?
Old Oct 13, 2006 | 03:20 PM
jon@work's Avatar
jon@work
Yeah - get yourself a bigger oil filter (I think the old Sherpa ones fit) and an oil cooler rad. These together won't make a massive difference though, IMO.
Is there no way to get a cossie sump on, modified to clear the crossmember and then wide-winged, with the correct oil pick-up pipe with the piston cooling jets? Would probably be your best option.
Old Oct 16, 2006 | 01:59 PM
BigDave's Avatar
BigDave
Or just but big wings onto the RS2 sump if you cant get clearance at all?
What crossmember did you use by the way? I would have thought that using a world cup type you should get clearance for a Yb sump? You may need to trim back one of the lower edges slightly but it sould fit in a similar way to my Mk2 set up?
With regards to filters, you could fit an ally take off and then use a remote filter housing set up higher in the engine bay. This would give you extra oil in the lines if thats what you were after?
Or try a Accusump that holds an additional shot of oil in various quantities and gives it to the engine when required.
CheeRS
Old Oct 17, 2006 | 11:25 AM
C0S_TURBO's Avatar
C0S_TURBO
Thanks for the advice! I have just modified the standard Anglia 105e cross member. The clearance is between the road and the button of the sump. I have probably mounted the engine to low in the engine bay. All part of learning. Bit of a pain now though. I am just worried about there not being enough oil at high revs. I have now brought a mocal oil cooler kit from Think. Will fit it this weekend. Just need to find some room!
Cheers!
Old Oct 17, 2006 | 01:19 PM
BigDave's Avatar
BigDave
Think sell the Accusump kits. They protect from oil starvation so could be just what you need?
I would like to see your modified Anglia crossmember. Must be well braced to take the extra pull!!
Good luck fella.
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
