3 door coilover spring rates??
Can anyone with a 3door trackcar with coilovers on give me an idea of the rear spring rates please. I've checked mine and they are 200lb.
I think they are too soft ??
Ok.
It must be something else that is causing the rear to be twichy. Its very unstale turning into a corner. Once the weight has moved and loaded the outerside its ok. The only thing that has been changed are the rear beam bushes and the coilovers fitted.
Adam Graham
Sep 6, 2015 06:04 AM
