Boost guage fitting?
Finally got around to fitting my new electronic boost gauge, Theres a small boost sensor supplied in the kit, I need to tap into a vacuam line in the same place you would with a normal boost guage. The instructions are very vauge as to where the best place to do this is?
Have you removed the airbox for a cone filter?!
If so use the outlet that the pipe off the inlet went to the airbox. Or if need be T off that one. Would avoid doing it off the mapsensor one!!!
Ok I tee'd into the brake servo line right beside the inlet plenum and before the check valve in the line. At idle the boost gauge shows -20psi, when I rev the engine however it won't go into positive figures just goes as far as 0 as I lift off and the dump valve activates. What am I doing wrong?
CabrioTurbo
Aug 1, 2015 11:04 AM
