sapphire Backing plates
Old Oct 5, 2006 | 02:47 PM
capri280's Avatar
capri280
Default sapphire Backing plates
Anybody know where i can get these
Old Oct 5, 2006 | 03:26 PM
cosrep's Avatar
cosrep
Excuse my ignorance but whats a backing plate?
Old Oct 5, 2006 | 09:50 PM
Daveesaunders's Avatar
Daveesaunders
I was going to ask the same thing
Old Oct 6, 2006 | 07:56 AM
capri280's Avatar
capri280
They are the plates that sit vertically to the rear of the rear hubs and brake calipers
Old Oct 6, 2006 | 11:57 AM
Daveesaunders
If I understand correctly your after the splash plates that sit behind the discs. I believe Granda ones fit but I'm not sure. The Sierra ones are now obsolete, I'm running mine without them.
Old Oct 6, 2006 | 01:43 PM
broos3's Avatar
broos3
From: Linlithgow and Drives a 1989 Flint Grey Sierra Cosworth
If you are meaning the rubber disks that are on the hubs to protect wheel from brake dust. My cossie has a set, nit sure if i want to part with them though. Is that the parts you are talking about??
Bruce
Old Oct 12, 2006 | 06:31 AM
rstoughy's Avatar
rstoughy
Backing plates are the thin metal covers that sit in behind the rear hubs sheilding the discs from the inside.
When we rebuilt my brothers rear beam we just left them out but if you do fit a set get them powdercoated before you fit them or they will just fall apart after 6 months
Old Jan 2, 2007 | 01:02 PM
capri280's Avatar
capri280
up
Old Jan 2, 2007 | 08:10 PM
Jimboxr4x4's Avatar
Jimboxr4x4
I thought I read somewhere its an MOT failure to remove them?
Old Jan 3, 2007 | 09:17 AM
rob741's Avatar
rob741
Ive seen a set on ebay a while back but they are very rare now
Old Jan 3, 2007 | 05:47 PM
dakar's Avatar
dakar
mk 3 scorpio granada ones fit just put a set on mine and they fit a treat and available from ford for about 9 quid each can get u part number if need be
Old Jan 3, 2007 | 09:18 PM
Daveesaunders
Nope mine have been removed for 4 years and never failed yet. If you were to fit larger discs you'd have to remove them then anyway.
Old Jan 4, 2007 | 07:38 AM
dojj's Avatar
dojj
Resident Wrestling Legend
spalsh sheilds or whatever aren't they?
i've got a set i took off that were a bit worse for wear if you are DESPERATE for them
you can probably tidy them up if you want the bling factor but you realy don't need them and they certainly aren't an mot failure, and besides, you will get more air flow over the brakes so they should work better too
Old Jan 8, 2007 | 11:33 AM
adam rs's Avatar
adam rs
Default backing plates
Try lee at fusion fabrication he made some for my 4x4 cossy! He fabricated them out of aluminium and made a shit hot job! www.fusionfabrication.com
SmudgerByName
52
Jul 28, 2016 06:14 PM
lukeeboy149
Aug 22, 2015 04:29 PM
Neatrags
Aug 16, 2015 07:57 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
