differences between a T3, T34, T35 and T3/T4 hybrid
Old Oct 4, 2006 | 11:13 AM
jyguad's Avatar
jyguad
Default differences between a T3, T34, T35 and T3/T4 hybrid
Hi
I have a Sierra cosworth 2wd stage 2 or 3 (i'm not sure)
I have a T3 run at 1.7 bar (1.5 1.6 stab)
can you give me the differences between my T3,a T34,a T35 and a T3/T4 hybrid?
I need a safe 1,7 bar of boost with a very low lag
thanks for your help
JY
Old Oct 5, 2006 | 12:06 PM
killa_paul's Avatar
killa_paul
If i can remember correctly
A t3 is a standard 2wd turbo.
this at stage 1 is the same turbo fitted with a 360 deg bering.
stage 2 is then a bigger inlet housing and fan blades
a stage 3 is then a bigger exaust housing on top of that.
a t 34 is just a stage 3 turbo and thats just what they call it and thats the same as a t3 hybrid
a T4 however is the rs500 turbo which has the bigger inlet housing and a bigger still exaust housing
its been a while but i think thats about it, a hybrid T4 is the T4 with a 360 bering
the 360 bering allows you to run higher levels of boost.
hope that helps
although i might not be 100% correct?
someone may be able to clarify
the stage of the hybrid depends on what break you want to be able to run. not sure how that equates in to bar......
send these gys an e-mail. they are very helpfull and imo do the best turbos.
http://www.turbotechnics.com/docs/index.htm
thnks Paul
Old Oct 6, 2006 | 07:59 AM
jyguad's Avatar
jyguad
thank you for your help
what about lag for this turbos?
Old Oct 10, 2006 | 12:05 PM
killa_paul's Avatar
killa_paul
well there is some lag with the bigger turbos, but you can get an anti lag kit
Old Oct 13, 2006 | 09:23 AM
jyguad's Avatar
jyguad
What is a anti lag kit ?
where I can find one ?
Cosnada
Jan 7, 2016 05:30 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Russ Payne
Sep 25, 2015 08:29 PM
