Engine coolant temp sensor cossie
Old Oct 3, 2006 | 08:58 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Default Engine coolant temp sensor cossie
When the engine is at normal temp say after cruising for 20 minutes, does the CTS sensor have any influence on the ECU? I mean when the resistant of it has become below a certain value because the engine is warm enough, does the ECU still uses the value?
The reason I ask because my car is running very lean when the engine is cold or hot. Have tried a numerous of thing, but still haven't found what's the reason.
Rewired the fuel pump, checked the fuel pressure and all is fine.
Hope someone can help me with the question about the CTS.
Old Oct 3, 2006 | 09:11 PM
Stu @ M Developments's Avatar
PassionFords Creator
It uses it at all times the ignition is on.
Old Oct 4, 2006 | 06:59 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Thanks Stu,
I tried to get this answer by users on PF so I didn't had to disturb you again...
So can it be that if this CTS hasn't got the right restistant through the whole range (say for about 15 % less resistant from cold to high temp) it's leans the engine from cold start to hot?
And is the CTS more for fuelling and the ATS more for advancing the ignition?
Old Oct 4, 2006 | 07:17 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the coolant sensors normally either work or not, they don't tend to go out of range. it's only a simple NTC resistor.
when they don't work and have an open circuit, the ecu reads that as cold and richens the mixture, not the other way around
Old Oct 4, 2006 | 07:50 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
I measured the resistant of the CTS when it was cold and hot:
Cold is 4,79 kOhms, warm is 215 Ohms
The ATS is at cold 4,51kOhms (Tamb= 16 degree Celsius).
To give you an idea how lean the car runs at full boost (greens, 1,3 Bar etc):
at 3000 rpm it says 15,09:1 (1,02)
at 4000 it says 14,41:1 (0,98) and
at 5000 it says 13,82:1 (0,94)
So that it didn't meld anything is a miracle!
Old Oct 4, 2006 | 10:04 AM
foreigneRS's Avatar
foreigneRS
Testing the future
those afr figures don't tell us anything about it being dangerous unless you tell us other things like boost
the resistance vs temperature of the act and ect sensors is roughly as follows:
resistance = 0.0036 * temp ^ 4 - 0.109 * temp ^ 3 + 1.2462 * temp ^ 2 - 6.7031 * temp + 15.289
hth
Old Oct 4, 2006 | 02:43 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
hth
Don't have a clue how to read this formula of you...
Maybe if I put up a dynosheet of my rolling road session it tells you a lot more, peaks at 1.5 Bar, holds 1.3 Bar
T3, SS exhaust, greens, msd chip, 3 bar map sensor and -31 actuator:
Old Oct 4, 2006 | 09:07 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Old Oct 5, 2006 | 08:41 AM
foreigneRS's Avatar
foreigneRS
Testing the future
YBJ sorry, made a mistake with it.
i used excel to plot the data of the resistance vs temperature data as below and asked it to add a trendline with equation but it was bullshit.
ignore the formula, and just read off the values from the chart.
http://img.photobucket.com/albums/07...CTECTGraph.jpg
you will see that your measurement of
is correct
if you want to check that your sensors are working, MSD now sell some software so that you can connect your ecu to a laptop computer, called IAW Monitor. get in touch with stu, or see this topic
https://passionford.com/forum/viewtopic.php?t=206547
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Roosie
Aug 15, 2015 08:09 PM
markk
Aug 15, 2015 01:38 PM
