HELP!! Ever fitted 15" gti rims to a series2?????
As above ive just got some escort Gti rims 15" so i can keep me diamond cuts in the garage over winter Trouble is my normal wheel nuts/bolts dont fit the wheel very well and are going to chew through the stud holes on the wheels as the collar is not big enough,
does anybody know what wheel nuts will fit properly as im strugglin at the moment
Thanks
Thanks
i find that bit strange coz the diamond cut bolts and colars should fit the gti wheel 100% as theyre all the same as far as im aware. i had 16inch mondeo rims on mine and then just got some diamond cuts and the nuts and collars are fine
Originally Posted by Rab
Not trying to be funny, but Escort GTi wheel nuts should fit quite well
Get some from a Mk6 down your scrappys
wellnot trying to be funny myself but Gti 's have whell NUTS and erst's have bolts
And they are Diamond cut standard rs turbo rims not Rs sevens
So i still need to find out what bolts to use please people
ooooooooooohhhhh, appologies mate lol, ithought u meant they were the 17inch diamond cut rs rims lol.
in that case, in order to fit gti rims, u will need to go to a wheel place and buy some new bolts that have the correct taper on them. if u take a gti rim with ya, they can find the perfect fitting ones
JoeyBoyden
Jan 4, 2024 02:36 PM
mrice0107
Aug 21, 2015 07:55 PM
