got no spark...
Old Oct 3, 2006 | 05:10 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Default got no spark...
engines in ...all ready to go...but ive got no spark.....changed every sensor and now im putting the old ones back in....when u turn the ignition on it sparks...then turn it to start it and i loose the spark....W.T.F..... any daft little thing i could have missed....cheers
Old Oct 3, 2006 | 05:17 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
Sounds a little like the cranck / speed sensor
I guess it is an cossie?
Old Oct 3, 2006 | 05:20 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
you get 1 spark when you switch the igniton on. Have you got the wires round the right way on the phase sensor?
pete mcrash
yes it is fella....checkt that, i need a volt meter to check power at different connections next
Old Oct 3, 2006 | 05:23 PM
pete mcrash
its started to rain,so ive come inside, so start again 2moro after graft
Old Oct 3, 2006 | 05:29 PM
ECU Monitor Enthusiast
Check you havent got the phase and crank sensor plugs swapped
Old Oct 3, 2006 | 06:18 PM
Stu @ M Developments's Avatar
PassionFords Creator
Especially on a 4x4, as its easy to get teh knock sensor plug wrong too.
Failing that, id check teh phase sensor polarity is correct as well as its alignment, and you must NOT take any notice of teh timing mark on teh FRONT.
Old Oct 3, 2006 | 06:35 PM
pete mcrash
nice one guys....try it again 2moro
Mkbatten
Jan 9, 2015 11:11 AM
Unkle_bootz
Aug 17, 2012 11:35 PM
Rsmat
85
Apr 7, 2012 12:38 PM
Rsmat
23
Mar 27, 2012 07:16 PM
Charlie Chalk
31
Jan 28, 2008 01:11 AM
