Rear springs
Old Oct 3, 2006 | 02:42 PM
PewteRS's Avatar
PewteRS
Default Rear springs
How the hell do you get the rear springs off coz the huge bump stops are in the way.
I dropped the rear arm and they still wont come out
Old Oct 3, 2006 | 04:01 PM
RS500/364's Avatar
RS500/364
use some spring compressers
Old Oct 3, 2006 | 04:11 PM
THE RADMAN's Avatar
THE RADMAN
undo the rear drive shafts at the outer end,undo bolt in the brake line t piece at rear of car and gently lower the arm,and brakelines, obviously mind you dont kink the brakelines dont try and force it with the d/shafts connected or you will damage the outer casings and make them oval shaped
Old Oct 3, 2006 | 07:37 PM
Glenn5's Avatar
Glenn5
angle grinder thats what i used, but i was fitting coilovers so had total disrespect for the springs other than that as above remove driveshaft
Old Oct 3, 2006 | 07:40 PM
MONSTER's Avatar
MONSTER
Just undo the 3 bolts holding the rear beam in place, they come out easy peasy then Just do 1 side at once though or your beam will fall out
Old Oct 3, 2006 | 07:51 PM
GAZ345's Avatar
GAZ345
remove bottom shockie bolt, pull arm down as far as brake pipes will let you,push off rubber bump stop, spring compressors then pull spring out from side of car
Old Oct 3, 2006 | 08:52 PM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
i removed the rear shaft and lowered the arm unbolting the shocker and that was fine to get ithe spring out
Old Oct 3, 2006 | 11:14 PM
PewteRS's Avatar
PewteRS
Cheers guys i'll give it another go
S3an
13
Sep 13, 2015 10:01 AM
Topjoe9
Sep 12, 2015 09:50 AM
truffleshuffle
Sep 10, 2015 09:35 PM
Adam Graham
Sep 6, 2015 06:04 AM
cossirob
Sep 3, 2015 09:17 PM
