boostdrop after gearchange....??
Old Oct 2, 2006 | 12:57 PM
Gregor's Avatar
Gregor
Default boostdrop after gearchange....??
After my problem with my turbo on my ZVH engine i've come across the next problem.
Did a quartermile sprint this weekend and i noticed that after i've changed gears it takes a while before i get ful boost again. This takes about half a second.
What could be causing this??
I've got a cosworth 4x4 intercooler at the front with a tube above the i/c to get the air back to the charge carrier side ... could this be to long??? i've already got a reverse charge carrier to shorthen this traject..!
But would this solve my problem..
Thanx again!!
Old Oct 2, 2006 | 04:30 PM
Rick's Avatar
Rick
it's called tubo lag
Old Oct 2, 2006 | 04:43 PM
Chris69's Avatar
Chris69
chuck a dump valve on there that'll sort u out
Old Oct 2, 2006 | 05:27 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You're joking right?
Old Oct 2, 2006 | 05:29 PM
Chris69's Avatar
Chris69
no, of course not
Old Oct 2, 2006 | 05:43 PM
John Laverick's Avatar
John Laverick
And some underbody neons!!
Seriously mate....it sounds about right to me!
Old Oct 2, 2006 | 06:11 PM
Gregor's Avatar
Gregor
Wel.. when i'm doing above 3500 rpm when i'm in next gear i don't expect as much lag as i'm getting (it's not building boost or something, but just staying the same revvs it seems ) ... well anyway... and yess.. i've got a dumpvalve on it....
Old Oct 2, 2006 | 11:00 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Take dump valve off and see what happens, i'll be VERY suprised if you don't notice a difference.
Otherwise as said at the top, turbo lag
Old Oct 3, 2006 | 06:49 AM
Badman38's Avatar
Badman38
run a small shot of nitrous then you will Eliminate that problem, i run nitrous purely for drag racing spools up the turbo Instantaneously between gear changes
Old Oct 3, 2006 | 11:08 AM
Christian and Beccy
#1 in Spelling Club
That's fine on a big-spec car, but to cover up a problem that to most isn't really a problem, I wouldn't suggest it.
Mine doesn't use NOS and still has 2-Bar by just over 4000rpm.
Old Oct 3, 2006 | 12:13 PM
Badman38's Avatar
Badman38
but then bring nos into the Equation and have 2-bar by 3000rpm will make your car faster over the 1/4 mile
Old Oct 3, 2006 | 12:36 PM
Gregor's Avatar
Gregor
Will try that this week... thnx
Old Oct 3, 2006 | 01:00 PM
Badman38's Avatar
Badman38
dump or blow off valves are not needed for any of the t series turbos unless you run a t4 they dont produce enough back pressure, and they are as tough as old boots unlike the gt series turbos
Old Oct 3, 2006 | 06:33 PM
DaveyBoyS1's Avatar
DaveyBoyS1
Maybe look at a different turbo... gt(something) rolllerbearing or anti-lag. Just a suggestion.
Old Oct 3, 2006 | 06:36 PM
DaveyBoyS1's Avatar
DaveyBoyS1
Edit: just seen your sig... anti-lag? I was gonna go gt series turbo... wud be interested to know if they were pants.
Old Oct 4, 2006 | 06:50 AM
Badman38's Avatar
Badman38
m8
gt series turbos are the bollocks i've ran one for the last three years, low lag they move a huge amount of air.you have to run a dump or blow off valve with these due to the thin shaft.only problem to repair them you have to get a new core which is not cheap
Old Oct 4, 2006 | 04:27 PM
Gregor's Avatar
Gregor
Well, just took of the dumpvalve.... and got out on the street...
Could't really test it because it's a bit rainy over here and as soon as the turbo spins so do the wheels so it'll spin up quiker now anyway....
Hopefully a bit dryer tomorrow for some more testing but i don't think it wil make a big difference....
couldn't the long airintake be a couse of this all./...... otherwhise it's nothing else but TURBOLAG>>>>
Old Oct 5, 2006 | 10:04 AM
Gregor's Avatar
Gregor
tested it today.... when i'm high in revvs and change quick the wheels spin in 2nd andn boost is there instantly. When it does't spin it drops in revvs more and takes a while before it picks up properly.....
I hate LAG....
Old Oct 5, 2006 | 12:26 PM
Badman38's Avatar
Badman38
I hate LAG....
what gearbox are r you running?
Old Oct 5, 2006 | 12:32 PM
Gregor's Avatar
Gregor
Standard box for now with ap fast road clutch.
It's making really weird noises so am looking for an uprated item but dunno what kind yet..
Old Oct 5, 2006 | 01:31 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
CTS
www.gearboxman.com
Old Oct 5, 2006 | 02:29 PM
Gregor's Avatar
Gregor
Yea i know that one... thnx anyway, but was hoping to get a place over here... don't think that's gonna happen so will have to get it from there i think ....
Old Oct 5, 2006 | 06:50 PM
Arjan's Avatar
Arjan
I got one from CTS, shipped to Holland. no probs. only downside is paying for the shipping costs which is quite high considering the weight, and you pay extra for doing an outright purchase.
however, you will get a very decent box that will take alot of abuse
Old Oct 6, 2006 | 08:02 AM
Gregor's Avatar
Gregor
Hej Arjan,
What stage of box have you got?
What are the total costs if i may ask?
If it's to expencive to send i'll just have to pick it up there
Old Jun 17, 2007 | 09:31 AM
Gregor's Avatar
Gregor
Well.. got the aluminium rad. and cts box in for a while now but i'm stil not happy with that turbo....
really want to get some decent boost @ arround 2500 rpm or so.
i've got a stage 3 turbo now ( 0.48 exhaust hausing, cosworth comp. wheel , 360 degr. bearing )
Whould it be better for a quicker spin up to put on a standard turbine and housing ( 0.36 ).
Doesn't have to run silly amounts of boost, arrond 18 psi.
Or just go to all standard Turbo ( for now ) wich spins up quick enough ( so i've heard ) on a ZVH engine.
Thanks
Rockhound
Jan 8, 2011 07:53 PM
