Engine cuts out then fuel pump stays SOLVED
Old Oct 1, 2006 | 09:41 AM
jrs's Avatar
jrs
Default Engine cuts out then fuel pump stays SOLVED
Just put my new engine in started fine but die's after a 1 min or 2 the fuel pump stays on and you can here the injectors going mad i've tryed relays but no joy If i leave the car for some time does the same thing starts ok sound ok but starts to play up and when it die's won't start after as it flood's it self all management is the same as before and i've taken the chip out
IT was the edis module
Old Oct 1, 2006 | 09:44 AM
Avinitlarge's Avatar
Avinitlarge
HA ah, Mine used to do this with OFAC management, What management have you got??
Old Oct 1, 2006 | 09:53 AM
jrs's Avatar
jrs
Ofab
Old Oct 1, 2006 | 10:09 AM
Avinitlarge
Ive never found the fault, Changed all the sensors, The chip, EDIS, Checked all the wiring but never found the fault, On mine it was intermitant though, Could be ok for a month then do it or it could do it 2 or 3 times a day
Old Oct 1, 2006 | 10:11 AM
jrs's Avatar
jrs
mine's all the time
Old Oct 1, 2006 | 10:19 AM
Avinitlarge
this is the post I put up a while ago
https://passionford.com/forum/viewto...light=#2940587
Old Oct 1, 2006 | 10:39 AM
jrs's Avatar
jrs
Could you here your injectors going mad? That can't be the C.P.S could it i've converted a s2 block to take EFI
Old Oct 1, 2006 | 11:06 AM
Avinitlarge
Yep the injectors go mad, They turn on and of, the fuel pumps turns on and off, It floods, The last time it did it was last week on the motorway on my way to work, I pulled onto the hard shoulder turned the engine off and then back on and it has been ok since, I really doubt its the CPS, I unplugged the EDIS and the injectors still were going mad
Old Oct 1, 2006 | 11:17 AM
jrs's Avatar
jrs
Old Oct 1, 2006 | 01:34 PM
jrs's Avatar
jrs
As mine is doing it all the time i've unpluged the main injector plug and you still here the fuel pump on all the time then plug that back in and unplug the fuel pump and i can here the injector's going mad this is all with just one click of the key doe's this mean my ecu is fcuked
Old Oct 1, 2006 | 02:04 PM
Avinitlarge
I would say it is ECU or loom related, Thats what I think mine is
Old Oct 1, 2006 | 02:18 PM
jrs's Avatar
jrs
Think your right mate my money is on the ecu i had a cheap chip in there
Old Oct 1, 2006 | 06:38 PM
Avinitlarge
Spoke too soon, It did it again today, Luckily I was paked at home when it happened, The car was idling on the drive then suddenly cut out, It just sat there clicking the fuel pump on and off, I turned the ignition off and then started the car, It was ok then. I would really love to know what this fault is
Old Oct 1, 2006 | 06:58 PM
jrs's Avatar
jrs
Me too as i've had my car off the road for months and now it's all done and i can even drive it to a garage Im try to get an ecu to see if it's at fault
Old Oct 5, 2006 | 09:27 PM
jrs's Avatar
jrs
kosienutter
31
Aug 22, 2015 09:55 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
