Aftermarket mnagement help..............
Old Sep 30, 2006 | 06:59 AM
403ayb's Avatar
403ayb
Default Aftermarket mnagement help..............
After messing around with various cossies and rst's i thought i have a go at having aftermarket management on my latest little project, a zetec turbo S2.. Anyway.. im having a few problems!!!! and my friend that runs a local engineering company that supplies the management has just gone away on holiday!!!Typical!!!
Basically all the management is in and working but the car only starts few 4-6 seconds then quickly leans off and dies... i have been through all the sensors, components etc etc and everything, i think, is working, yet sometimes it will run for longer and others not long.. And it wont rev up at all with anything more than lite thrttle...
Atm as soon as lamda is coming in the thing just over corrects it self over 50% and..wel u kno wot happens..
We have tried everything, i think, loads of fuel, fuck all fuel, loads of pressure to eff all pressure, ign retard/advance bla bla bla...
Can anyone help or suggest anything im being stupid with of forgeting?
(the management is KMS, a relativley new managment but ive spoken to loads of other happy users and myself being on of them on another car!!! so i dont kno if theres a component on the car causing this or just the twat behind the wheel... )
Thanks ppl...
Old Sep 30, 2006 | 02:04 PM
DazC's Avatar
DazC
Could it be the mapping at fault if it's not been set up yet?
Old Oct 1, 2006 | 07:13 AM
403ayb's Avatar
403ayb
Thats wot i thought but we have to base maps on the laptop from 2 other zetec turbos that i kno that have been used already and various other maps that have run similar cars, wel at least until it can get driven to the rolling road or to be run in first...
Please can someone help....doing my nut in now....
Old Oct 1, 2006 | 08:39 AM
NUTS RuS's Avatar
NUTS RuS
How is it seeing the revs ?
Is there a throttle pot connected and is it correctly adjusted for 0 - 99%
Old Oct 1, 2006 | 10:23 AM
boost mad's Avatar
boost mad
it has its own coil pack driver as is takes its tacho read off that. it does run a tps and yes that is adjusted correctly. its running a 3bar map sensor and that iis calibrated aswell.....
although , i have just had a thought, obviously pressure/vacuum changes with slight throttle yes???? well it does on the boost gauge, but not on the laptop....... hmmmm
Old Oct 1, 2006 | 11:21 AM
sexr3i's Avatar
sexr3i
isn't it
no leaks from vac hoses then?
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
YODI
Aug 30, 2015 01:12 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
costina
18
Aug 25, 2015 06:02 PM
