what polishes?
same question different colour sorry, what would you recomend on mallard green and crystal blue (would be nice not to have to buy 2 differant sets of polish)all advice will be welcome,and what would you recomend for cleaning white wheels. cheers in advance andy
Poorboys Natty's Blue Wax would work fine on both if you want a carnauba wax giving a clear, wet look, or Four Star Ultimate Paint Protection is a sealant that is a really bright finisher, and lets the metallic really show through.
You can use the sealant, then the wax on top if you want added protection underneath the wax and still get a fantastic shine...... Both products are dead easy to use as well so shouldn't take too long to do both.
For cleaning the wheels Four Star Wheel Cleaner is a good, ph neutral option, so very kind when cleaning, if theres any stubborn bit's you may need a claybar to help pick off whats stuck..... Then get some wax / sealant on them to help protect and make them easier to clean in future. (sealant will last longer on wheels compared with a wax but either will do).
I've also had excellent finishes on the above colours using ClearKote Carnauba Moose Wax as well as Natty's - CMW gives an even wetter finish.
Once the wheels are clean PB's wheel sealant is a great product to protect and to leave an excellent finish. PB's wheel cleaner, Spray and Rinse, is also an excellent strong product for shifting baked on dirt...
Gareth
Gareth
Mc5506
Oct 5, 2015 09:57 PM
caprixpack
Sep 25, 2015 07:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
Indyrs
20
Sep 1, 2015 09:04 AM
