escort mk 6 cab e/roof
Old Sep 24, 2006 | 09:13 PM
fiestaturbo1984's Avatar
fiestaturbo1984
Default escort mk 6 cab e/roof
hey just brought a mk6 escort ghie cab with electric roof but the roof aint moving. havent really had a proper look but the pump in the boot does make a noise when you push button. any ideas on what to look for??
Old Sep 25, 2006 | 01:33 PM
escort cab's Avatar
escort cab
check there is hydraulic fluid in the pump (it has a gauge on the side. Also checked that the tbar peice that sticks out of the pump is fully closed.
What also can happen is the hydraulic rams can come un bolted from the hood frame - this can damage the hood and frame badly so i would check that as well
Worse case senario would be the pump is knacked and thats mega bucks for a new one.
hope this helps
Old Sep 25, 2006 | 06:29 PM
MarkN's Avatar
MarkN
The pumps have a plastic cog in them that tends to break. In this case you can still hear it working but it won't do anything.
The Escort Cabriolet Club were selling rebuld kits for these pumps quite cheaply a while ago, - might be worth getting in touch with them.
Fingers crossed someone's left the bypass valve on the side open, but you'll be lucky...
Old Sep 25, 2006 | 06:33 PM
fiestaturbo1984
woohoo thanks for replies guys, jus been working on it i checked the pump and there was no fluid but a lil bit around bottom of pump so im guessin it has a leak somewhere but filled it up and after a bit of wd40 around hinges she be working fine
Old Sep 26, 2006 | 10:57 AM
SafeChav's Avatar
SafeChav
Glad you sorted it
What fluid did you use?
Old Sep 26, 2006 | 05:52 PM
fiestaturbo1984
just some old hydraulic shit i had in the shed. just want to see if and where it leaks
Old Sep 26, 2006 | 06:04 PM
SafeChav's Avatar
SafeChav
Ah right fair enough.
Does anyone know for definate what they should have in them?
benw456
Sep 16, 2015 05:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
