Gear Linkages
How much wud it cost to replace them, becoz ive just had the gearbox rebuilt. However, the gearbox dosnt feeeellll nice.
If i was to get a shortshifter, wud it do the job?
B&M quickshift does away with all the standard linkage rubbish so if your sure it is your linkage thats playing up then yes it would.
B&M is about £180 from APT
Originally Posted by TURBO BOI
am i right in saying that the quick shift replaces the linkage and bushes at the drivers end but the gear box end bushes could be shagged?
there is nothing on the gearbox side of the linkage, there is a gearchange stabalizer bar which only has a plastic washer and then there is the main selector rod which can only be adjusted for desired gear selection smoothness and tightened
I supose doing the mod on the link above may be worthwhile but i found just buying original ford replacement parts for the linkage done the world of good. I now use the b&m quickshift which is great.
****EDITED BY WEBTEAM****
only goldmembers can sell items
you have to drop the old stick and linkage out and just replace a couple of plastic bushes inside the mechanism, so it has to come off the car but this aint difficult. Make sure you take it apart very slowly so nothing breaks then you can see how to put the new bits in. Be sure to adjust the linkage correctly on refitting because that is the most important thing.
yeah when removing the old linkage be careful cause as i took mine out it fell to pieces. lol
scotty86d
do a search on here, that rally design one isn't that good according to most people who used them.
scotty86d
The Youth.
Sep 30, 2015 09:59 PM
