RST Fuel hose queery
Old Sep 17, 2006 | 02:26 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Default RST Fuel hose queery
Plastic fuel hose on an S1 from pump - accumulator
Mine snapped off, so I replaced with a rubber one
original ones inside diameter looks allot bigger, well 2-3mm bigger
My question is, will this affect fuel pressure, under load acceleration. . would i be better upgrading so the inside diameter was the same size or will this cause no problems being smaller?
cheers.
Old Sep 17, 2006 | 06:42 AM
steven botes's Avatar
steven botes
shouldnt make a difference - i use 5mm id fuel hose on all my hoses
Old Sep 17, 2006 | 10:58 AM
SafeChav's Avatar
SafeChav
Have the hose as big as you can without it being a sloppy fit and/or leaking.
You will be able to use slightly bigger internal diameter hose than that.
One tip though, cut all the plasitc hose off and use rubber from one connection to the other, its very hard to clamp rubber pipe to the plastic ones and not have it leak SHORT of squashing the plastic and therefore causing a restriction. I had to replace the very same hose on a friends series 1
Old Sep 17, 2006 | 01:58 PM
vroooom ptssssh
It Wasnt Me!
http://cgi.ebay.co.uk/Escort-S1-x2-S...QQcmdZViewItem
Thinking of getting these, will need to ask mike R if he can do em cheaper!
also need to find out what inside diameter is, if it's just the same then probably not worth it,
Thing is, the car's overboostin by about 4-5psi set up std 7psi, so when you boot it, it doesnt like it. . brrr pop bang etc. . (unless you let the boost build up a bit slower than jus flooring it) but it's chipped so no boost cut or anything at 11-10psi, but if it's underfueling it might? or if that fuel hose is restricting it enough to make it do that? or my shitty plug leads need renewed. . so could be a couple of things so jus gonna eliminate them (whilst obviously working out why it over boosts (think I know why so no worry their)
cars
Old Sep 17, 2006 | 02:01 PM
SafeChav's Avatar
SafeChav
Or it could your dizzy is fucked just like every other RS
The internal diameter is about 7mm, outside diameter is 8mm.
I'd just use normal hose mate, those braided hoses are very nice but they will put the rest of the hoses to shame then! And they ain't exactly cheap
If you cut the plastic off the end pieces, rubber pipe clamps onto the fittings perfectly
Old Sep 17, 2006 | 02:48 PM
vroooom ptssssh
It Wasnt Me!
Dizzy is cool, was fine before it started overboosting, went like a dream
Ive only clamped it onto plastic hose at the accumulator end, banjo end the hose is clamed to the banjo itself.
would like to braid all hoses, gotta start somewhere
Old Sep 17, 2006 | 03:32 PM
DazC's Avatar
DazC
The pressure will be ok but the actual flow will be reduced.
Old Sep 17, 2006 | 05:32 PM
vroooom ptssssh
It Wasnt Me!
would this be likely to cause any probs Daz that you are aware of?
Think for all it costs i'll upgrade it in size!
Old Sep 17, 2006 | 06:24 PM
DazC's Avatar
DazC
Depends if it restricts flow enough to cause a problem on hard boost at peak volumetric efficiency...
It might run lean.
Old Sep 17, 2006 | 09:16 PM
vroooom ptssssh
It Wasnt Me!
Now listed as £30. . just need the one hose tho so see if he can just supply that
Old Sep 18, 2006 | 11:23 AM
SafeChav's Avatar
SafeChav
Davvy, thought you said theres someone on here that makes them cheaper? Does he do brake lines aswell as im after some
Old Sep 18, 2006 | 12:24 PM
vroooom ptssssh
It Wasnt Me!
Mike Rainbird I think does them, and probably beats prices!
Im sure I saw someone on the RST forum say they can get them for free as they work for a company that does em, but bit cheeky to ask and forgot who it was, they got a red RST im sure if that helps
Old Sep 18, 2006 | 01:56 PM
SafeChav's Avatar
SafeChav
Oh yeah, a Red RST, thats narrowed it down i know who u mean now
Old Sep 18, 2006 | 02:47 PM
vroooom ptssssh
It Wasnt Me!
Sorry Chavvy, but ignore that if it's beyond brain capacity and consentrate on "Mike R"
Old Sep 18, 2006 | 07:32 PM
SafeChav's Avatar
SafeChav
You've lost me
Old Sep 18, 2006 | 10:28 PM
vroooom ptssssh
It Wasnt Me!
Mike R is the main person to talk too.
this other person works for a place and said he can get em free IF you can be arsed to hunt with the little details
didnt say he was the sole supplier
Old Sep 18, 2006 | 10:36 PM
SafeChav's Avatar
SafeChav
You plank!
You missed the joke lol
And i'm just about to read your reply on my mk3 end caps thread and i bet its some pointless sarcy reply thats about as much use as a cock flavoured lolly pop
Old Sep 19, 2006 | 12:23 AM
vroooom ptssssh
It Wasnt Me!
Old Sep 21, 2006 | 09:16 AM
ivorbiggun's Avatar
ivorbiggun
Kevin's braided hoses are FANTASTIC he's also managed to effect a fitting
to connect to your solid fuel pipe that,-
1, is easy to connect/disconnect-how many of you have managed to disconnect the plastic Ford ones without breaking them or a special
tool?
2,I've tried others from 'others' and they've always leaked.
3,The 'lets see if I can get it cheaper elsewhere' attitude is EXACTLY why FORD WILL NOT ever release another RS Cosworth/'too many either too
tight or just unable/willing to stump up the nescesary'........
I'm paraphrasing a conversation one of my drivers had with Lewis
Bo**h about 18 months ago!
Old Sep 21, 2006 | 10:20 AM
SafeChav's Avatar
SafeChav
tool?
Ooooooo, oooooooooooooo, i have
What do i win?
Old Sep 21, 2006 | 11:26 AM
ivorbiggun's Avatar
ivorbiggun
One years 'free' access to I'vegotnodoughandnoideahowtomaintainaperformanceca r.com
ie here
mille congratulzzions as they probably don't say anywhere Andrew
Old Sep 21, 2006 | 11:34 AM
vroooom ptssssh
It Wasnt Me!
Well I sent the guy on ebay a message, "how much for just the hose from the pump-accumulator" bearing in mind it's £35 delivered for the two
reply: £25 delivered.
I was expecting say £20 - £15 for the hose (half price) and maximum £5 delivery
Suppose it's either I get that or rubber stuff. . prob jus get rubber, I like the feel of it
Old Sep 21, 2006 | 01:10 PM
SafeChav's Avatar
SafeChav
Just stop being a tight arse and buy both!
Mr "i want to change them all and have to start somewhere"
Old Sep 21, 2006 | 01:36 PM
ivorbiggun's Avatar
ivorbiggun
Thing with the hose and jubilee clip route is....,-
Almost invariably when you switch off the negative vacume will (it always
finds a way) suck air in which of course leads to a lot of those entertaing 'my
car won't/is difficult to start' moments/threads.
Old Sep 21, 2006 | 02:15 PM
JesseT's Avatar
JesseT
What's wrong with black nylon fuel pipes?
Old Sep 21, 2006 | 03:05 PM
SafeChav's Avatar
SafeChav
I'll be fucked if i know..............sounds like the "turn off negative vacuum" is greater than the pressure the pump produces.
Yeaaaaaaaaaaaaaa.................ok then
Old Sep 21, 2006 | 05:12 PM
Rick's Avatar
Rick
I'd like to try some of that negative vacume too....
Old Sep 21, 2006 | 05:59 PM
ivorbiggun's Avatar
ivorbiggun
looks as tho the genius' know more than me and Ford/the non return valve on the pump serves a purpose does it not? But if the plastic pipe is lashed up with bits of rubber pipe and jubilee clips air is bound to ingress hence the above...
Old Sep 21, 2006 | 08:35 PM
DazC's Avatar
DazC
PMSL @ "Negative vacuum!"
Old Sep 21, 2006 | 09:00 PM
Rick's Avatar
Rick
Looks like they do!!
Old Sep 22, 2006 | 10:15 AM
SafeChav's Avatar
SafeChav
Indeed.
If the pressure the pump creates can't make the pipe connections leak petrol, theres no way the "negative vacuum" will let air ingress.
The one way valve is stop the fuel system losing pressure, which is especially important for K & KE jetronic, being as the injectors are pressure operated.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
Chas
Oct 5, 2015 07:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
