just back from rolling road...NEED ADVICE please
well lads just got back froma rolling road set up and this is the result
179.9bhp
178of torque
mods:
superchipped ecu
pro alloy front mounted
kent cvh 35 cam
and pully
t3 hybrid with .48 exhaust
mongoose full system
-31 actuator
ok, so we ran the car and got the fueling spot on first making sure she wasnt leaning out before upping the boost , all i waas able to run was O.8BAR
seems to be the actuator its screwed right up and its peaked and held 0.8 bar .....
next wee set up the cam it ran a 168 before the cam was dailed in and then it ran 179 so happy with that ...
so it made 179.9bhp on 0.8 bar of boost not bad .....just worndering why when a -31 is screwed right up did it only make 0.8 with no leaks as system was all tested for leaks and its a new actuator as well ???
179.9bhp
178of torque
mods:
superchipped ecu
kent cvh 35 cam
and pully
-31 actuator
why? if u reconnect the valve does it up the pressure? im a bit confused i understand that u disconnect the amal valve so that ur able to run higher boost than the 9psi set by the factory ??? can someone please tell me if this is true ?
right i connect the amal valve and its made no difference at all
any other suggections? and ive tryed two different actuators and both the same result .... the turbo is a t3 with a 0.48 exhaust housing using a -31 ...whats could be the problem thats it only allowing 0.8 bar off boost ?
ive it plumed in just the wee connector on it mate, but explaine this...it ran 14psi on the old t3 standard with the same actuator bit on this turbo ive it wond rite up and only 0.8bar ..and the amal valve has been the same for both turbos
IS it piped up correctly?
W is for the wastegate actuator
R is return to metering unit
C is for compressor housing
You may have to jet the amal valve. There is a small white plastic restrictor in one of the ports of the amal valve. You may need to open the hole up very slightly.
Make sure it is connected electrically too as the ECU will be trying to open and close it to bleed air off and increase the boost. If the ECU can't control the valve, it will remain closed and just send the air straight through to the actuator (essentially making the pipe from the compressor housing and the one from the actuator a straight peice of pipe).
If you can't get it to work properly with the amal valve, you may need to get hold of a 3 port manual bleed valve (Stu@ MSD has them in stock I think). RS Turbos need a 3 port one to work properly and you just replace the amal valve with it using the 3 pipes from the amal valve.
right i understand what u are all sayig about the amal valve but its been the same on the standard t3 as it was with the hybrid t3 and i was able to run a bar or more if i wanted on the standard t3
yea was thinking of doing that rick just too see what happens lol but hoprfully not bad lol ill take it easy give it a bit in 4th and see if the boost goes over 0.8bar and if soo then ill know its my actuator ..??
Perhaps I expect a little too much in life but,-
Shouldn't the rolling road operator have told you what was wrong?
Also, get rid of that daft cam put a standard one in it and watch your torque jump up to 200 ftlbs at lower revs.
andy130
Oct 2, 2015 08:48 PM
