Autronic with secs
Old Sep 13, 2006 | 10:05 PM
Kelv's Avatar
Kelv
Almost there!
Default Autronic with secs
Possible?
As the Secs monitors only sit in line on the main engine wiring loom and pick up the signals that are being sent back to the ECU, does it matter what ecu is being used??
my thoughts are that it shouldnt make a diference if the correct pin/wire can be proved on the management thats being used for that sensor.
being that the standard senors are still being used (air temp, water temp etc) so the same resistances will still be coming thru the loom back to the ECU and the monitor picks them up before theyve been read by the ECU.
so could it be possible to use a Secs monitor with the SM2 im going to be using??
Old Sep 13, 2006 | 10:10 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Kelv just get one of these instead
http://www.mrm-racing.a.se/autronic_dashracepak.asp
Old Sep 13, 2006 | 10:14 PM
Kelv's Avatar
Kelv
Almost there!
Yeah been looking at those but i want a stack dash in the main housing.
dont know anyone with the aim dash to see what they look like other than on a pic like that!
good side of the aim dash's is they allegedly plug straight into the autronic ecu's
Cheers Richie
Old Sep 13, 2006 | 10:27 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Cheers Richie
nigel b has one in his Series 1 mate. Saw it at Combe, looks
His site is http://www.seriesone.net/
15
Oct 7, 2015 03:43 PM
pabloXR
Sep 21, 2015 12:42 PM
Bailes1992
Sep 3, 2015 02:17 PM
K42L
Aug 28, 2015 01:23 PM
Bailes1992
Aug 16, 2015 07:14 PM
