what will i need to do to my engine.....
Mate i have a stage 2 turbo technics hybrid with two stage boost, 7.8:1 comp ratio with the fith injector.
Power slams in at 3.5 ish, now i dont run the high boost anymore because im iffy on the longevity of the rods and piston not to mention the turbo.
But id like to hear opinions on this so discuss away lads
Depends what parts ur after. Pistons: Somewhere like woodford or PJ do good deals. You want STD MAHLE pistons.
Gaskets - from ur ford dealer. ARP bolts - Rally Design. Turbo - shop around - Turbo Technics stuff is shit hot though. Shot peening of rods - any machine shop. Head work - i'd say Cylinder head developments for what you need.
My engine was specced for 300 bhp and was going to have 7.8:1 pistons fitted.
Been toying with EFI though ut im getting the shell restored in a while once the funds are together so i can a good few rot less years out of her, she a beauty!
Originally Posted by JezSierra
someone said i should get a jamsport stage3 head?would it be worth me getting it?
if you can, get one.
they are 350+ vat give them a ring
With a ported head, you won't have to run as much boost and the stresses will be lower on the turbo as a result.
Sorry, I should have made that comment a little clearer now I have read it.
You won't have to run as much boost to get 220bhp with a ported head than you would with a standard head.
whywontyoustart1983
Jan 20, 2011 04:58 PM
-J-
29
Apr 7, 2005 06:31 PM
