CD Rom problems
Old Sep 13, 2006 | 12:06 PM
JonnyBravo's Avatar
JonnyBravo
Default CD Rom problems
Recently I've had afew problems with my cd rom reading cd's.
Usually when you put a cd in it will automatically open whatever it is and now it doesn't If you go to your cd drive on the desktop and open that it doesn't show any files ?
I've just taken the pc back to the shop in town that built it as i wanted the cd rom replaced, they tried 2 new units on it and they both done the same thing.
All the interal cables have been changed so its not that either, IF you hold the cd rom after you have loaded it with a cd you can feel it spin a few times then it stops as if there is nothing in there ?
Something isn't right thats for sure tried re-installing the drivers and updating my pc but that also made no difference.
Anyone on here good with these odd faults ?
The guy at the shop said he had a similar fault with a pc once that turned out to be something to do with the registry settings ? not something I fancy playing with tbh.
All I need to do is put some damn music on my pc so I can get it on my Ipod for the cannonball
Any advice ?
Old Sep 13, 2006 | 12:18 PM
Stu.H's Avatar
Stu.H
If they built it, get them to fix it!
If new cdroms have been tried, then its only one of 2 things;
OS
or
Motherboard
Good luck!
Old Sep 13, 2006 | 12:27 PM
JonnyBravo's Avatar
JonnyBravo
I totaly agree mate.
I only kept the pc for now as I need it to get a lot of maps and files off before I go away on friday.
Itunes problems is minor but bloody irritating, I will leave it with them for the week I'm away as there are many thing not right with it since I got it.
I was just trying PF as amazing what people actually know on here !
Old Sep 13, 2006 | 12:33 PM
Adrenaline Junkie's Avatar
Adrenaline Junkie
If i've read that correctly its just not reading the disc at all?
So its not to do with the CD autoplay function?
I would have suggested checking autoplay was enabled, and that it was set to ask you everytime a disc was put in, but if its simply not reading anything thats in the disc drive i'm not too sure?
Old Sep 13, 2006 | 01:09 PM
JonnyBravo's Avatar
JonnyBravo
Nothing to do with Autoplay mate.
It just simply doesn't read any cd.
Other drives have been tried and they all do the same.
Bit of a weird one
Old Sep 13, 2006 | 01:39 PM
AndyBlackFRST's Avatar
AndyBlackFRST
Can you view anything if you use another application instead ofwindows explorer??
Check with iTunes, Roxio etc.
Otherwise give it back to where it came from and get them to fix it
Old Sep 13, 2006 | 04:40 PM
JonnyBravo's Avatar
JonnyBravo
It doesn't work on anything mate.
I only want it to work on Itunes for now but that wont have it.
What is strange is that it did sort of read a totally fooked Coldplay cd last night, but it was so knackered it wouldn't copy it, I brought a new copy and it wouldn't read it
Has a mind of its own ! but I just thought the noises coming from it would be the fault but as we have now tried 2 new units on my pc and they do the same thing so its some other hardware/software related problem.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
