Any Sony laptop experts or repairers? help needed
Old Sep 13, 2006 | 07:58 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Any Sony laptop experts or repairers? help needed
I have a Sony Vaio A317M laptop which has always worked fine but now refuses to power up (completely dead no lights nothing), when I press the power button nothing happens at all.
The last time it was used I left it unattended and the battery ran flat, the charger is producing power but the laptop shows no sign of it being connected when it's plugged in.
Anyone know anything about these or anyone who repairs them?
Old Sep 13, 2006 | 08:10 AM
angel45's Avatar
angel45
check the power pack first Martin, you sould get a light showing when the laptop is charging
Old Sep 13, 2006 | 08:13 AM
cfoster's Avatar
cfoster
Does the laptop power up with the charger plugged in? It could well be that the battery is stuffed.
Old Sep 13, 2006 | 08:19 AM
Martin-Hadland
How you doing Efe long time no speak
The power pack is producing power and the green light on the charger is illuminated. I can't remember if the laptop itself has a lamp that’s illuminated when the charger is turned on ... do you know? I have noticed the socket on the rear that the charger plugs into is slightly loose but I'm pretty sure it's always been like that.
I'm wondering if the laptop is not getting the charge (faulty socket?) and simply wont turn on because the battery is flat, I prob need to try a charged battery in it to see but I only have the one that’s in the computer.
Old Sep 13, 2006 | 08:20 AM
Martin-Hadland
No, nothing at all. This is a mystery because until this no problems ever.
Old Sep 13, 2006 | 08:40 AM
RANJ's Avatar
RANJ
remove the battery and try and run straight from mains first
Old Sep 13, 2006 | 08:51 AM
sm's Avatar
sm
when its running on mains it should show a small green light on the front of the laptop along side the battery light, etc have tried contacting sony?
http://www.vaio-link.com/index/index.asp?l=en
ive got a vaio 217m laptop the keyboard died a few months ago emailed there support team and they took me through a few tests and i sorted the problem, they also do reapirs for a small charge
hope this helps
Old Sep 13, 2006 | 10:22 AM
JohnnyB's Avatar
JohnnyB
agree with ranj, in most cases if the bat is detected as dead it will not start up
Old Sep 13, 2006 | 11:10 AM
angel45's Avatar
angel45
Hi Martin
should run directly off the mains, give me call if needed Martin, got a Vaio @ home so you can try my charger out if this helps
Old Sep 13, 2006 | 11:11 AM
Ish's Avatar
Ish
I think Martin has alraedy tried running it with no batt in and just the mains adapter connected and it didn't work.
No lights on the laptop come on with adaptor connected.
Old Sep 13, 2006 | 11:44 AM
angel45's Avatar
angel45
cheers ish, spoken to Martin
Old Sep 13, 2006 | 11:57 AM
L33 BYT's Avatar
L33 BYT
My Vaio used to have a problem similar. I used to take out the battery. Take out the pSU and hold my finger on power button for 20 seconds.
Then try it with PSU plugged in and see if you get any life.
It was something to do with a static build up.
Old Sep 13, 2006 | 12:02 PM
Adrenaline Junkie's Avatar
Adrenaline Junkie
My work laptop has packed up too... its not even an old laptop, only a few months old!
Thats an IBM thinkpad one, so whilst that gets repaired, i'm using a nice HP one.
Bloody pain in the arse Laptops when they don't work!
borboyous
Aug 22, 2015 11:17 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
