starting problems
Old Sep 13, 2006 | 01:41 AM
oakey dokey's Avatar
oakey dokey
Default starting problems
alot of people seem to have starting problems with erst but mine does it when its hot! i drive 40 miles to work every day when i get there i allways let it cool down on idle then turn her off but if i try to start it again i get all the lights but thats it nothing the pump clicks in! my last rs started to do this just before i sold that one anyone know what this could be? thanks oakey
Old Sep 13, 2006 | 06:44 AM
Badman38's Avatar
Badman38
Default Re: starting problems
check the wires on the starter motor, The down pipe is very near to the starter motor solenoid the main feed from battery is not the problem its the small tigger wire on the starter motor, what happens the heat from the exhaust heats the bolt which Eventually works lose. either repair or replace the starter motor and heat wrap the down pipe.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
