spark plugs
Sep 12, 2006 | 10:07 PM
spark plugs
does anyone no the plug gap for denso iridium plugs
Sep 12, 2006 | 10:19 PM
depends on boost. 0.65 is a good place to start.
Sep 12, 2006 | 10:25 PM
it peaks about 15 them drops to about 12-13 psi
Sep 12, 2006 | 10:30 PM
id go for 0,75mm then to start with, and close them up if u get a miss - v unlikely that you will.
Sep 12, 2006 | 10:32 PM
Hi,
99% certain they are pre gapped What is the part number
Dave R.
Sep 12, 2006 | 10:33 PM
hi i think it is Ik 22 i will have to take 1 out and have a look
Sep 12, 2006 | 10:36 PM
Denso are pregapped. At 15psi u will not have a problem. in my experience, it's when u go over 20/21 that the ign system is really tested.
Sep 12, 2006 | 10:39 PM
do you no what the pregap is because i have set them to 0.8mm thanks
Sep 12, 2006 | 11:15 PM
not for certain, but i would bet on around .75
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
