Mk 4 efi XR3I cutting out
Old Sep 11, 2006 | 05:13 PM
NICK K's Avatar
NICK K
Default Mk 4 efi XR3I cutting out
AS above . Any ideas ?
i have tried idle screw co and idle valve
Old Sep 11, 2006 | 09:30 PM
Tom Phillips's Avatar
Tom Phillips
Default crankshaft sensor?
when its cuts out does start straight away? if you havent already tried it, pull the plug out for the crankshaft sensor, clean it, wd40 will do, then try it. this plug is located where the engine mates onto the gearbox, on the exhaust manifold side down the bottom.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
Fudgey
21
Sep 30, 2015 06:19 PM
