E.F.I CONVERSION?
Old Sep 7, 2006 | 08:45 PM
mercury grey minter's Avatar
mercury grey minter
Default E.F.I CONVERSION?
What,s better/advantages to using FIESTA OR COSWORTH MANAGEMENT.I know on COSSIE MANAGEMENT you keep the dizzy,but not sure about loom.Am basicallly looking for the EASIEST or CHEAPEST and MOST EFFECTIVE WAY of getting rid of M.F.I. Have heard of people converting from anywhere between £400-£1000.Your views or conversion costs PLEASE.
Old Sep 7, 2006 | 08:51 PM
Lincolndanny's Avatar
Lincolndanny
i too would like to know as im fed up of how shit mine is to start
Old Sep 7, 2006 | 10:59 PM
TURBO BOI's Avatar
TURBO BOI
Best mod i ever done changing to efi, done mine for around £300
Old Sep 7, 2006 | 11:03 PM
Rab's Avatar
Rab
Fucking superstar........
It's well easy. Can be done for peanuts. Buy a Mk4 EFi XR3i and get all the stuff you need from that.
Then get hold of an OFAC/OFAB ecu and map sensor from a fez turbo, an inlet manifold adapter plate and a sierra 1.8CVH CPS sensor and your singing and dancing. Then break the rest of the 3i and recover your costs.
Old Sep 7, 2006 | 11:08 PM
cammyR10's Avatar
cammyR10
hmm my mates got an efi xr3i in his field might have to go on a mission
Old Sep 7, 2006 | 11:09 PM
Rab's Avatar
Rab
Do it mate. Works so much better. And takes up alot less space in your Mk2 bay
Old Sep 7, 2006 | 11:10 PM
TURBO BOI's Avatar
TURBO BOI
yeh get rid of that metering unit
Old Sep 7, 2006 | 11:11 PM
gambit's Avatar
gambit
Default efi conversion
i have all the bits from my xr2i that i broke, are these any good?
i am thinking of going efi but cost is an issue. i have:
inlet manifold
injector rail
loom
head
flywheel
most sensors and injectors
Old Sep 7, 2006 | 11:12 PM
Rab's Avatar
Rab
They'd all work just fine mate.
All EFi heads are the same, Fiesta Turbo or not.
Old Sep 7, 2006 | 11:21 PM
gambit's Avatar
gambit
super
Old Sep 8, 2006 | 10:23 PM
radiant red's Avatar
radiant red
in the middle of my conversion got a few more bits in the post today,i will be running 701's with a stage two motosport development chip.
Old Sep 9, 2006 | 01:34 PM
JamboRS's Avatar
JamboRS
focus rs 1672
what airbox do you use when going efi?
Old Sep 9, 2006 | 04:37 PM
radiant red
i reckon the cone filter will be used on 99.9%
Old Sep 9, 2006 | 05:39 PM
JamboRS's Avatar
JamboRS
focus rs 1672
what about the other 0.1%,i would like to be that percentage,so what would my options be,can a 3i one be converted?can a turbo one be converted? or would it need to be custom?
Old Sep 10, 2006 | 11:23 PM
mercury grey minter
O.K you say it is easy,so hope you can explain a few points.
1.How much loom do i swap,is it just the ENGINE LOOM and do i need to take the DASH out?
2.I here you have to MACHINE the crank pulley from a 1.8 sierra. to make it fit.
3.Did you encounter any problems in doing the conversion,modding the wiring plug E.C.T.
I don,t want to start a conversion until i know what,s involved and what to look out for.
CHEERS.
Old Sep 11, 2006 | 12:03 PM
davsmith64's Avatar
davsmith64
you will need..
efi inlet manifold complete with injectors and injector loom
coil pack
cps sensor and/or trigger wheel depending on your block
xr3i/festa turbo loom
ofab or ofac ecu
fuel and injector relays
adapter plate if u are using a mfi head
efi flywheel.
you will need all the sensors for the loom, i.e map sensor, tps, iat etc..
Old Sep 11, 2006 | 03:12 PM
TURBO BOI's Avatar
TURBO BOI
Originally Posted by davsmith64
you will need..
coil pack
ofab or ofac ecu
efi flywheel.
also you will need a 90 xr3i throttle cable and pedal
Old Sep 11, 2006 | 03:13 PM
TURBO BOI's Avatar
TURBO BOI
CHEERS.
dont need to take dash out, just wire up fuel pump and injectors seperate, speak to rab for his special wiring diagram
Old Sep 11, 2006 | 03:44 PM
Rab's Avatar
Rab
Have a look on craig's topic for my diagram
https://passionford.com/forum/viewtopic.php?t=220964
This is for wiring up the fuel pump and relays for the EFi.
Old Sep 11, 2006 | 04:46 PM
davsmith64's Avatar
davsmith64
ohhhh yeah,,
so u do need to change the cable and pedal as i need to change it as i have done the efi conversion to my ERST,,,
heres a few pics of it converted..
Old Sep 11, 2006 | 06:31 PM
mercury grey minter
Are we all agreed that
1.MK4 ESCORT XR3I E.F.I
2.MK3 FIESTA RS TURBO.
3.MK3 FIESTA XR2I
All have EXACTLY the same INLET MANIFOLD,ENGINE LOOM AND COIL PACK....Basically i want to get as much parts as i can from XR2i or xr3i.Are the only FIESTA RS TURBO parts i need..
1.E.C.U.?
Old Sep 11, 2006 | 06:48 PM
davsmith64's Avatar
davsmith64
mo u will need the matching map sensor for the ecu aswell,, i.e if u get a fiesta ofab ecu u will need an ofab map sensor,,
also if u use a xr2i inlet and sensors u will need to change the act sensor for a frst one as it will give a false reading to the ecu and make the car run incorrectly..
also i dont know if this has been pointed out, if you do use a xr3i loom u will need to make a few changes to it to run the ecu on ofab..
but if u use a OFAC ecu it should just plug in and run the car..
and also u will need a edis4 module and when u do get one make sure u cut pin 2 out as it is not needed..
if u need anymore help give us a shout..
Old Sep 11, 2006 | 06:59 PM
mercury grey minter
Have ben offered an XR2i.Can you give me a small list of what EXACTLY i need from a FIESTA RS TURBO.Also ,whats the difference between OFAB/OFAC? Cheers.
Old Sep 11, 2006 | 07:03 PM
craig rs's Avatar
craig rs
blimey
Old Sep 11, 2006 | 07:08 PM
Rab's Avatar
Rab
An XR2i will provide EVERYTHING you need except, the ECU, Map sensor and CPS sensor.
And obviously the adapter plate for the inlet.
Old Sep 11, 2006 | 07:11 PM
craig rs's Avatar
craig rs
theres a xr2i in my local scrapy been there for yonks with the engine intact
Old Sep 11, 2006 | 07:14 PM
Rab's Avatar
Rab
Buy it and get everything you need mate.
Old Sep 11, 2006 | 07:15 PM
mercury grey minter
And that,s defo everything i need from a FIESTA RS TURBO.?
Old Sep 11, 2006 | 07:16 PM
Rab's Avatar
Rab
From the tubro you'll need the ECU and MAP sensor.
This is all. The rest you can get from the 2i, or 3i.
Old Sep 11, 2006 | 07:23 PM
mercury grey minter
Cheers RAB Do i get the CPS sensor and pulley. from any 1800 cvh sierra?Also what needs to be done to the pulley to make it fit.?
All help appreciated
Old Sep 11, 2006 | 07:55 PM
Rab's Avatar
Rab
Jambo, you can use the OE airbox. Fits really well.
For the info on the CPS sensor you'll have to ask Jano Oddkidd or someone more knowledgeable about that. I'm afraid I use a Fiesta Turbo bottom end. Tom, (TURBO_BOI) did it so you could ask hm too.
Old Sep 12, 2006 | 02:51 PM
JamboRS's Avatar
JamboRS
focus rs 1672
how does this work as the escort turbo airbox sits on top of the metering head with the o ring in between
Old Sep 12, 2006 | 10:37 PM
radiant red
use any box ya like just make it neet and tidy
Old Sep 12, 2006 | 11:54 PM
Rab's Avatar
Rab
You need to use a bit of pipe, which you could get from one of the many exhaust places abuot here, and use the standard hose from the metering head to the turbo. I just jubilee clipped the pipe into the hose, then jubilee clipped the airbox directly onto the bit of pipe. 3 cable ties to stop it flapping and I was away.
You should have seen how I ran it at first
In the end I shifted the battery and put an ERST airbox in it's spot.
Old Sep 13, 2006 | 05:39 PM
EssexMikeSi's Avatar
EssexMikeSi
ive got a level6 2wd saph ecu for sale if anyone is doin cossie management.
Old Oct 1, 2006 | 07:59 PM
Lighty's Avatar
Lighty
What about the petrol pipes... you must have to change them.
Old Oct 1, 2006 | 08:07 PM
©hatter Box's Avatar
©hatter Box
i done my efi cov over 6 years ago
Old Oct 1, 2006 | 08:08 PM
murdoch1.7zs's Avatar
murdoch1.7zs
RAB when you cuming up to help me
got everthing out the xr just need to get it in the rs
Old Oct 1, 2006 | 10:06 PM
EssexMikeSi
different people/companies have different theories to completing this conversion, some are shocking to look at. i followed janos theory on this. i was thinkin bout doin it, so looked on his website and forum and it proved to be more than helpful. im not gona give much away incase theres bits that he dont want people to know about, as u can prob understand. here is pic of my engine. my throttle cable is a normal escort rst item. ive heard a escort mk4 automatic item is better as its alot shorter, but no one could find me one
Old Oct 1, 2006 | 10:13 PM
EssexMikeSi
i must add, i cant recommend this conversion enough. using a cossie 2wd engine loom and then just taping up what wasnt needed from my escort turbo loom, an jus puttin it bundled up behind the heater box. i could have chopped it all off, but didnt wana ruin a perfectly good,never been cut escort turbo loom, incase i ever decided to break the car for spares. another way would be to get a escort mk4 base model engine bay loom to use with the cossie loom, coz this wouldnt have all the ecu wiring etc.
hope im being helpful here and not just rambling on lol
