Is it worth me upgrading to a T34??
As above my turbo has given up the ghost on the xr2 turbo (cossie t3) and was considering upgrading to a T34 BUT would I notice a difference / is it worth it on my spec engine???? Dont want to spend the money on one if i dont have to! Current spec is as follows:
1650 CVH
Cossie T3 turbo
Fully balanced and blueprinted
Blydenstein gas-flowed cylinder head with silicon valve stems
Low compression pistons (7.0:1 CR)
OFAC management
Escort Cossie Group A K&N Filter
Spec-R oil breather system
Ahmed Bayjoo Phase2 conversion
Beige fuel injectors
IB5 RS1800 Fiesta 5-speed gearbox
AP Racing clutch with uprated road/rally cover plate
It peeks at around 15psi but the turbo seals are foobered!!!!
I am considering going cossie management in the near future but not planning on upgrading to anything else (was going to go 16v but spending money elsewhere now!!)
Chris
1650 CVH
Cossie T3 turbo
OFAC management
Chris
Originally Posted by cfoster
ok cool cheers! Suppose get a standard rebuilt with 360 bearing???
Regards Doug .
