How do i remove my chav valev from my sapphire cosworth???
my sapphire cosworth 4x4 came with a dump valve which is getting on my nerves so ive bought a bung to go in its place but im unsure of what i need to block off elsewhere or where i need to plug pipes into etc etc. so any help including diagrams would be most appreciated
cheers
daz
cheers
daz
Take the dump valve off the large boost hose, put the bung in, tighten the hose clip around it. pull the small vacume hose off the dump valve, and either blank this off with a bolt that will fit tightly in and tuck it somewhere so it wont cause any trouble, or remove the T piece and connect it back upto the plenum, you should be able to see where it goes.
who me?? who said anything bout image im just bored of the noise the dump valve makes always wanted me own set of turkeys under the bonnet and thought now that i actually have the car ive always wanted, i might change things on it
i eat golfs for breakfast anyway
lukeeboy149
Aug 22, 2015 04:29 PM
