Bottom Crank Pully Bolt
Old Aug 21, 2004 | 06:12 PM
avengerpenguin's Avatar
avengerpenguin
Default Bottom Crank Pully Bolt
Anyone know what size the above is on a 2wd Saff
Old Aug 21, 2004 | 06:29 PM
RSrussell's Avatar
RSrussell
about 5cm long
i'm not helping very much am i
Old Aug 22, 2004 | 06:42 AM
avengerpenguin
Anybody know, I need to finish doing my headgasket today and have to buy the socket to do the cam belt
Old Aug 22, 2004 | 07:24 AM
starturbo's Avatar
starturbo
Unless its very different to other motors Ive had it will be 17 or 19mm.
Old Aug 22, 2004 | 07:48 AM
avengerpenguin
its very different then, the biggest I could find in my pit of a garage yesterday was a 23 mm and that was too small
Old Aug 22, 2004 | 09:05 AM
Daveyraveygravy's Avatar
Daveyraveygravy
Yup i think it's a 24mm if memory serves
Old Aug 22, 2004 | 09:08 AM
Cosworth4388's Avatar
Cosworth4388
24mm m8
Old Aug 22, 2004 | 09:25 AM
pee vee's Avatar
pee vee
Why does my crank pully bolt keep coming very slightly loose!!!!?
it makes the pully knock really really slightly
even with threadlock,
Old Aug 22, 2004 | 09:29 AM
richm's Avatar
richm
Make sure that the thick washer is fitted between the bolthead and the pulley, also the big belt guide washer between the pulley and the crank (belt side)
Both these must be fitted to clamp the pulley properly. If the pulley is knocking, it needs sorting out straight away.
Old Aug 22, 2004 | 09:33 AM
pee vee's Avatar
pee vee
cheers matey.
Its on a Zetec BTW, not a cossie.
so that means there are no guide washers on the Bolt or the
pully Well its a shouldered Bolt.
Old Aug 22, 2004 | 09:38 AM
richm's Avatar
richm
cheers matey.
pully
ah.. ok..
same pretty much holds true though. the pulley needs to extend slightly beyond the end of the crank, and the external washer bears against the edge of the pulley to clamp it onto the crank. The external washer needs to be thick enough to ensure the bolt doesn't bottom out in the crank thread before the pulley is clamped tight.
**edit*** i just reread your post about the bolt.... now i'm not so sure - I'm working from memory of the last zetec i put together (an early one) .
Old Aug 22, 2004 | 09:41 AM
pee vee's Avatar
pee vee
cheers mate
i will go and have a look, see what i can find.
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
