boost without chip
ive got a bleed valve, think it would be ok to wind the boost up myself to that? as i havnt got a chip yet, or would other stuff need adjusting aswell to be safe?
i put a bleed valve on cos i got no amal valve (im running erst on efi)
but because i have no chip does it matter that if i wind the bleed valve out it wont go any further than 10psi? but for 10psi will i need the fueling to match of is it not gona make a difference at 10psi?
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
