boost without chip
Old Sep 6, 2006 | 03:15 PM
RST Ski's Avatar
RST Ski
Default boost without chip
Can i run more than 7psi without a chip? and normal injectors, i have a collins actuator
Old Sep 6, 2006 | 04:16 PM
wildheart's Avatar
wildheart
You should able to run just under 10psi
Old Sep 6, 2006 | 04:28 PM
RST Ski's Avatar
RST Ski
ive got a bleed valve, think it would be ok to wind the boost up myself to that? as i havnt got a chip yet, or would other stuff need adjusting aswell to be safe?
Old Sep 6, 2006 | 08:35 PM
wildheart's Avatar
wildheart
Stay clear of bleed valves!
You can adjust the boost via the actuator.
Old Sep 6, 2006 | 08:40 PM
RST Ski's Avatar
RST Ski
i put a bleed valve on cos i got no amal valve (im running erst on efi)
but because i have no chip does it matter that if i wind the bleed valve out it wont go any further than 10psi? but for 10psi will i need the fueling to match of is it not gona make a difference at 10psi?
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
