LSD BOX clonk clonk!
Old Sep 5, 2006 | 08:52 PM
Robliddle's Avatar
Robliddle
Default LSD BOX clonk clonk!
Need help!
When i select reverse in my ERST and start reversing back there is a nasty loud clunk clunk clunk noise coming from the front end and the car shakes about as its reversing seems to be worse when u lock the steering over. Ive had a few people say its the LSD but i have just had the box rebuilt for the second time with a new diff and it still makes the horried noise. Anyone got any ideas what could be the cause of it??
Old Sep 5, 2006 | 08:55 PM
gup's Avatar
gup
have you checked your c.v joints fella or drive shafts is their any play in the wheels at all are your g/b mounts good
Old Sep 5, 2006 | 11:08 PM
notSteveS2's Avatar
notSteveS2
or ur bushes on rollbar TCA's etc etc
Old Sep 6, 2006 | 04:27 PM
Robliddle's Avatar
Robliddle
Well ive replaced all thr bushes with poly ones and the drive shafts are brand new ones i bought about a month ago and this still did not cure the problem?
Old Sep 6, 2006 | 05:31 PM
gup's Avatar
gup
are the drive shafts slotted in correctly
jack the car up and spin the wheels to c if they are free moving
or to check that the g/b is not making any noise
Old Sep 6, 2006 | 07:17 PM
Robliddle's Avatar
Robliddle
The drive shafts are in properly, the noise seems to be coming from the g/b area, i wondered if the clutch could be failing.But surly it would make a noise when going farwards to?
Old Sep 6, 2006 | 07:22 PM
gup's Avatar
gup
it would make the noise when going forwards too
did you not check the clutch when you removed the g/b
also does it judder when you go to pull away
Old Sep 7, 2006 | 06:56 PM
Robliddle's Avatar
Robliddle
It only seems to judder when going backwards. I did not do the work on the gear box so i did not see the clutch .But the mechanic that did it would have cheaked it i would have thought.
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
