GAZ or AVO?
as above really. coil over comments in general?
BTW i noticed on the koni coil overs, they have progressively wound springs... anyone know where to get these?
saff is working!!!...atm
why coil-overs,never had them,bcos always been advised not to, if its a everyday ride just buy ur self a set of avo adjustables as they can be played with whilst in place and pick a set of dropt springs (are coil-over prices right down ?) i use my saff everyday and on the track, its sweet
Originally Posted by ellicoss
Dont even buy avo adjustables mate the adjuster sieze up then snap stay well clear
You will soon be able to free them off with a spanner if they get stuck
that would be good aslong as they put thicker shafts on the adjusters as there to thin on the rear and they neen to think about the rust issue on coil overs as they rust real quick
Originally Posted by Matt Lewis
AVOs are far better than GAZ IMO, AVO have redesigned there Coilovers to a far better standard
Matt
Matt
Totally agree Avos..... are far superior to gaz imo..
I have run konis and they where crap i now have Avo and will not change
full stop Avos all the way
From a motorsport point of view there is NO comparison between the two.
AVO are fit for competition, GAZ are fine for road in my eyes.
Other than thicker plating its hard to stop rust on any coilover. They can't be treated as a fit and forget item like a normal powder coated shocker.
They are derived from motorsport use and as such need to be looked after. If yours have rusted so bad then thats your fault for not looking after them correctly
