power/performance
Old Sep 4, 2006 | 06:42 PM
powerbio's Avatar
powerbio
Default power/performance
hi everyone,
ive been searching loads but cant find any info.
i know a standard erst is 130bhp, what is the next bhp figure attainable? i.e 170bhp? - with what mods??
with 170bhp what 0-60mph times, 1/4 mile times can be achieved?
boost pressure would also be a great help.
thanks
Old Sep 4, 2006 | 08:02 PM
andre_k's Avatar
andre_k
Default Re: power/performance
the next bhp figure attainable from 130bhp is 131 bhp.
for 170 bhp, on a pretty healthy engine, you need a chip, air filter and an exhaust system. then have her set up... voila
Old Sep 4, 2006 | 09:49 PM
notSteveS2's Avatar
notSteveS2
easily achieve 180bhp with chip, zorst, filter, -31 actuator and new set up with like 15psi...
of u wanna go more id advice new Intercooler.... then go from there!
Old Sep 4, 2006 | 09:53 PM
Rick's Avatar
Rick
depends on ur suspension, but about 7 secs is about right.
Old Sep 4, 2006 | 10:10 PM
dave_y's Avatar
dave_y
i have 188bhp and i got 6.95 at trax on sunday
that was my first ever go up the strip as well
Old Sep 4, 2006 | 10:56 PM
scotty86d's Avatar
scotty86d
6.95 is bloody respectable. well done!!!
Old Sep 5, 2006 | 04:42 PM
notSteveS2's Avatar
notSteveS2
well done matey... thats good for that power...
ur car still got all interior too???
Old Sep 5, 2006 | 06:41 PM
dave_y's Avatar
dave_y
yep still got full interior including spare alloy in the boot.
just after i did my run Dan from Fast Ford took a few pictures to use as a feature in the mag
Old Sep 5, 2006 | 07:10 PM
Oranoco's Avatar
Oranoco
Wanted to run mine but I objected to paying Ł7 to drive to 60
Old Sep 5, 2006 | 07:11 PM
JezSierra's Avatar
JezSierra
happy with that
where can i get a -31 actuator from?
Old Sep 5, 2006 | 11:09 PM
notSteveS2's Avatar
notSteveS2
see urs go at brunters tho...
Old Sep 6, 2006 | 11:47 AM
Oranoco's Avatar
Oranoco
Was in my other one on Sunday though. Was gutted with my times at Brunters Nothing to do with the car, I just couldn't drive it for toffee. It's capable of so much more but on the day I just couldn't drive for shit
Old Sep 6, 2006 | 11:56 AM
John Laverick's Avatar
John Laverick
Mine has 226BHP and the best I did a croft 0-60 was a 7.5 seconds
Bearing in mind it was the first time i'd ever tries, I only had 2 goes and the tyres has been round the circuit all day so were not in the best condition.
Still crap though
Old Sep 6, 2006 | 12:43 PM
dave_y's Avatar
dave_y
after getting 6.95 on my first ever go i preceeded to get 8.26 and 8.27 on the next 2 goes
on the slower runs though my fans had just cut in on the start line so im blaming it on them sapping 100bhp lol
Old Sep 6, 2006 | 01:49 PM
Rick's Avatar
Rick
as std u need to change in to 3rd which kills it - raised soft cut limiter makes it much quicker.
Old Sep 6, 2006 | 02:40 PM
John Laverick
Thats it Rick....
I have a soft cut Micro Dynamics limiter which is set 'just below' the standard hard cut limiter [effectively reducing my rev range slightly]. How would I go about removing the hard cut limiter and just relying on the soft cut one?
Any ideas?
Old Sep 6, 2006 | 03:17 PM
Rick's Avatar
Rick
easiest way is to fit an S1 fuel ecu, which has no rev limiter. You have to do a small wiring mod, but it works really well.
Old Sep 6, 2006 | 03:20 PM
John Laverick
Rick,
I'm not really up on the ECU's etc... in the RST. Is the fuel ECU the black one? [As opposed to the silver one that is 'chipped'?
I'm asssuming I should get the fuelling checked after changing the ECU?
Can you run through the wiring mod required?
n.b. Out of interest what provided the S1's rev limiter?
Old Sep 6, 2006 | 04:32 PM
Rick's Avatar
Rick
Two ECU's on the RST - Silver Ignition and boost control, Black fuel ecu.
There are 2 rev limiters - one in each ECU. When an ECU is chipped, it refers to silver ignition ECU, and most chips remove the rev limiter.
Its not as easy to remove the Fuel ECU limiter - it can be done by changing a capacitor inside. and this raises it to around 7200rpm. But, as it's an analogue circuit, and capacitors use a massive tolerance - you never know the true rpm limit if you do this.
The S1 has the ignition rev limiter, but doesnt have one in the fuel ECU.
The difference is in the wiring of the TPS - you need to bridge two of the S1 fuel ecu's terminals, as the the S1 ECU expects the TPS to earth through itself, where as on an S2 it is grounded to chassis earth...
Martyn
13
Apr 21, 2013 06:12 PM
xr_craig
15
Dec 29, 2004 06:25 PM
Martyn
Nov 8, 2004 08:26 PM
