Wheel alignment
Old Sep 4, 2006 | 03:19 PM
AndyRST's Avatar
AndyRST
Default Wheel alignment
When having your wheels aligned does this have any effect on the steering being central when the car is driven in a straight line.
Had 2 new front tyres fitted to the FRS today and they checked the alignment and found it was out 2 degrees on the near side so i agreed to have it realigned. Drive out the garage and the steering wheel isnt straight when the car is driving straight. I took it back to them to recheck it and they locked the steering wheel in dead straight and then rechecked the alignment and found it was incorrect by 1 degree so they corrected it and off i go again, except the steering wheel still isnt straight when driving the car in a straight line.
Now am i being too fussy, the steering wheel is about 4-5 degrees off centre towards the right Or have the garage done something wrong
cheers for info on it
Old Sep 4, 2006 | 03:29 PM
S1's Avatar
S1
I understand from previous posts on this matter that the FRS needs to be 4-wheel tracked. Although the fronts might be straight if the back end is steering to one side then you will need to correct it which means the wheel ends up on the cock.
Not sure how true this is, ive never had my FRS tracked up though.
Old Sep 4, 2006 | 03:47 PM
D.K.'s Avatar
D.K.
if it is at an angle when u let go of the steering but isnt pulling then the front and rear toe settings need adjusting, before the car is tracked the steering wheel should be moved left and right to take pressure off power steering if u have it and then locked in a straight posistion while the front toe is adjusted.
Old Sep 4, 2006 | 03:51 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
and done with the engine running, but they should know that lol
Old Sep 4, 2006 | 03:53 PM
BillyCabrio's Avatar
BillyCabrio
4 wheel alignment place in Sidcup Andy, where i had the cabbie set-up
Old Sep 4, 2006 | 03:59 PM
AndyRST's Avatar
AndyRST
Yep exactly that. It isnt pulling but the steering wheel isnt straight.
They did it with engine running and did wiggle the steering left and right few times 1st and they did lock the steering wheel in straight, but somethings not right
Paul, yeah might have to consider it
Old Sep 4, 2006 | 04:01 PM
BillyCabrio
AndyRST
Are you sitting up straight?
Old Sep 4, 2006 | 04:02 PM
D.K.'s Avatar
D.K.
take the steering wheel off and put it back on straight
Old Sep 4, 2006 | 04:08 PM
AndyRST's Avatar
AndyRST
CUNTS
Old Sep 4, 2006 | 04:12 PM
John Laverick's Avatar
John Laverick
Don't do this
My local alignment place did this and then the car failed the MOT because the wheel fouled with the inner arch on one side
Old Sep 4, 2006 | 05:48 PM
Phil DJ's Avatar
Phil DJ
My XR2i is the same. Got the tracking done and my steering wheel sits on the piss to the left
Old Sep 4, 2006 | 07:20 PM
D.K.'s Avatar
D.K.
Anyone in the newbury area give us a shout if you need ya tracking done and i'll do it for nowt, have to be a weekday tho saturdays we are well busy
Old Sep 4, 2006 | 07:24 PM
BigMouthBillyBass's Avatar
BigMouthBillyBass
I had a new tyre put on my Focus's front left after hitting a pothole. the sidewall developed a big egg and ever since it's been pulling to the left hand side slightly. Got it done at Benfield on York Rd, they probably didnt bother checking the tracking as it's a lease car and they don't bother spending any time on them
I'll have to get it booked in and checked out
Fiddy
21
Sep 29, 2015 06:10 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
