Handbrake adjustment
Old Aug 31, 2006 | 04:28 PM
RS EDDIE's Avatar
RS EDDIE
Default Handbrake adjustment
Does anyone know how i go about adjusting my handbrake tension, using the bias valves on the rear drums??
ive taken the rear wheels and drum covers off but dont know wot the halfords book is tellin me to do after, summink about measuring between 5 and 20mm movement.
It failed the mot on this being only 14%, so i need to do it sooner rather than later...
any help appreciated
Old Sep 2, 2006 | 01:43 AM
Jay246's Avatar
Jay246
go to the middle underneath of the car and you'll see a knob sort of thing wher the handbrake cable meets the handbrake... tighten this up
Old Sep 2, 2006 | 03:40 PM
daveselwood's Avatar
daveselwood
what car is it
Old Sep 5, 2006 | 08:38 PM
tanjaz's Avatar
tanjaz
please dont adjust it using the cable first this is incorrect. remove road wheels and drums. at the top where the shoes meet the wheel cylinder you will see and adjuster get a flat blade screwdriver and mark where the adjuster sits in case you need to return to where you started, then put the flat blade of the screwdriver in between the shoe and the cylinder on the adjuster side and lever gently this will bring the shoes out adjust the footbrake and the handbrake simultaneously. you just do it a couple of clips and refit the drum after removing any lips on the edge of the braking surface. if it goes on easily go a touch more if it is tight back the adjuster off slightly by separating the two sections with teeth this is the reason for marking it. when you have done this on both sides 9 times out 10 this will minmise the amount of footbrake travel and also sort the handbrake travel out if not this is the time you need to gradually adjust the cable ensuring it does not start to bind the brakes on. best bet is to have the vehicle jacked up and on axle stands and keep spinning both rear wheels to check for binding and also check the lever to ensure it has a small amount of free travel before you feel it start to pull the cable
hope this helps if you have not already done it.
Old May 9, 2007 | 08:32 PM
phill295's Avatar
phill295
as above well said
yatta
May 21, 2016 10:31 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
