HelpNeeded Please
Old Aug 29, 2006 | 07:01 PM
thething84's Avatar
thething84
Default HelpNeeded Please
Hi all.
i have a Mk1 Mondeo 2.0 16v.
I am having an problem with it, it starts ok and runs ok for a short moment. then it dies smelling very rich.
I noticed today that if i bleed some fuel using the fuel bleed on the injector pipe. its runs for a while longer after restarting it.
oh and the fuel level is very low in the tank.
Any idea's why this is happening.
Old Aug 29, 2006 | 07:07 PM
SafeChav's Avatar
SafeChav
Faulty injector(s) sticking open would be my guess!
Old Aug 30, 2006 | 12:08 PM
thething84's Avatar
thething84
any way of checking this
Old Aug 30, 2006 | 01:03 PM
SafeChav's Avatar
SafeChav
Remove the injectors and test them on a battery or similar. You should be able to feel and/or see them operating if they are good.
Old Aug 30, 2006 | 05:13 PM
thething84's Avatar
thething84
but surely if that was the case then it wouldn't run at all on tick over.
also if i touch the throttle when it is running, it dies instantly.
Old Aug 30, 2006 | 05:43 PM
SafeChav's Avatar
SafeChav
If say it was one injector it would still run.....and more than likely if two were stuck open....but it would be rich as fuck.......
Old Aug 31, 2006 | 06:16 PM
thething84's Avatar
thething84
yeh as i say. it run on tickover normal then just dies. if the throttle is touched it'll die instantly
Old Sep 3, 2006 | 12:07 PM
thething84's Avatar
thething84
any other suggestions would be muchly apprieciated. or else it will be a case of getting in a mechanic
i just remembered i have also pulled the original fit alarm module out. although i have plugged this back in to make sure this isn't the culprit. any suggestions.
