s2 acceleration problem
Old Aug 28, 2006 | 08:04 PM
moondust16v's Avatar
moondust16v
Default s2 acceleration problem
could anyone offer any help please??? my s2 recently started to cut out,
then failed to start due to poor connections at the fuel pump, now after amending this problem I have found another which it never had before.
when i start the car its fine, when i set off driving its fine but as soon as I put the foot down the bloody thing looses accelration instantly and splutters until I take my foot bac of the pedal
can anyone help????
thanks in advance
Old Aug 28, 2006 | 08:06 PM
Noisy Boy's Avatar
Noisy Boy
checked all your plugs, dizzy etc?
Old Aug 28, 2006 | 09:04 PM
NUTS RuS's Avatar
NUTS RuS
overboosting ?
Old Aug 28, 2006 | 09:48 PM
xrchris's Avatar
xrchris
i had this and it was just underfuelling, although with a co rading of 0.15 underfuelling wasnt the word.
chris
Old Aug 29, 2006 | 09:36 AM
moondust16v
yep changed all plugs, leads, and dizzy last week and everything was spot on
the boost hasnt been touched since i got the car and has been ok for last month
when driving it if i gradually put the foot down its fine it picks up speed, but the second i put the foot to the floor regardless of current speed of driving its like it chokes til I come off the pedal
Old Aug 29, 2006 | 10:38 AM
Chris69's Avatar
Chris69
sounds like a fuel block to me, had a very similiar problem with mine but it was worse- turned out the pressure regulator was almost completly blocked- theres a fair few components to the fuel system so its process of ilimination am afraid
Old Aug 29, 2006 | 11:25 AM
moondust16v
thanks 4 the advice guys
Old Aug 29, 2006 | 04:32 PM
Moonie's Avatar
Moonie
Check the hose between the metering unit and the turbo as they can go soft and collapse under the vacuum created by the turbo.
Old Aug 30, 2006 | 09:04 AM
moondust16v
ok i will check that cheers have checked all round the intake system and double checked all hoses were secure and in position, I am at a total loss as to what it could be,its wierd, when accelerating normally,it picks up fine, in all gears, say, for instance ,I am driving along at 30mph, if i slowly and graduially push the pedal the car picks up as it should , when changing gears up or down its fine its when i floor the accelerator wether it be from standstill or while driving hi or low speed,it just dies chokes n splutters til I take my foot off accelerator
Old Aug 31, 2006 | 10:39 AM
moondust16v
any one else got any suggestions???? please
Old Aug 31, 2006 | 10:56 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Mine was doin the same, and I never found out why! I dunno if it's doing it now as ive not had the car out for ages, but the hoses from the amal valve to actuator/turbo/metering unit werent all tight and it was overboosting so I put it down to that for now, also fitted a new fuel tank that I should of cleaned out before fitting, so wondered if it was something to do with that also.
I'd take it for a RR setup soon anyway as it's a new car to you and you dont know much about it or it's setup, precautionery if anything but probably well worth it !! Best place up out neckof the woods is AVA.
Old Sep 1, 2006 | 10:15 AM
moondust16v
cheers mate already got it penned in for a RR session with AVA
thanks again for all your help
Old Sep 1, 2006 | 10:21 AM
vroooom ptssssh
It Wasnt Me!
No probs, good luck at AVA
Old Sep 1, 2006 | 01:55 PM
moondust16v
thanks m8! thats if a keep it long enough the more i look into this car the more unsure i get about it............
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Marino
Sep 12, 2015 11:10 AM
