Help before my RS kills me
Old Aug 27, 2006 | 07:03 PM
PeteS2RST's Avatar
PeteS2RST
Default Help before my RS kills me
Got a major problem with my brakes they seem to work when they want to sometimes they will lock up with no breaking at all and other times it seems as though i'm not braking. Its still got ABS with std rear drums and grooved discs and uprated pads on the from i'm using dot 5.1 fluid and have bled the breaks twice in the last two weeks
Any suggestions greatly appreciated
Pete
Old Aug 27, 2006 | 07:06 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Is it the rear wheels that lock up?
Old Aug 27, 2006 | 07:40 PM
PeteS2RST's Avatar
PeteS2RST
no only seems to be front and lock up easier if i'm cornering if that helps
Old Aug 27, 2006 | 10:03 PM
HORNETS7's Avatar
HORNETS7
are the flexi pies on the fronts correctly mounted in the cupped holder and rubber gromet as they might be getting caught up when cornering?
Old Aug 27, 2006 | 11:24 PM
NUTS RuS's Avatar
NUTS RuS
Sounds possibly servo related to me
Old Aug 28, 2006 | 07:50 AM
PeteS2RST's Avatar
PeteS2RST
rubber hoses look fine servo is corroded underneath where the master cylinder mounts onto it could this be my problem also is there a way of checking the rear load compensators to see if there working okay?
Old Aug 28, 2006 | 08:01 AM
NUTS RuS's Avatar
NUTS RuS
Jack the car up and put it on stands.
Then jack the arm up and see if the mechanism is moving inside.
Old Aug 28, 2006 | 09:45 AM
PeteS2RST's Avatar
PeteS2RST
Just got jack and stands out ready to try the above and would believe it the heavens open will try as soon as it stops cheers all for your help. got new(ish) servo on the way
Old Aug 28, 2006 | 02:21 PM
NEWTON's Avatar
NEWTON
try the rear compensator valve[load sensors] see if there foooked
Old Aug 28, 2006 | 02:40 PM
PeteS2RST's Avatar
PeteS2RST
Will try when rain finally stops. if they are fooked can i get new ones or is there a better alternative???
Old Aug 28, 2006 | 03:28 PM
NEWTON's Avatar
NEWTON
you can get new ones but there about £90 each
Old Aug 29, 2006 | 10:21 AM
PeteS2RST's Avatar
PeteS2RST
hAVE CHECKED BOTH REAR LOAD COMPENSATORS AND BOTH APPEAR TO BE WORKING. TOOK THE CAR TO MY LOCAL MOT STATION TO HAVE A BREAK TEST DONE AND FOUND THE FOLLOWING
N/S FRONT 200
O/S FRONT 0
N/S REAR 0
O/S REAR 120
N/S HANDBRAKE 150
O/S HANDBRAKE 160
HAVN'T A CLUE WHAT THIS MEANS AND THE MECHANIS DIDN'T REALLY EXPLAIN IT TO ME
I PRESUME IT MEANS THAT I HAVE NO BRAKING EFFORT ON THE CIRCUIT THAT GOES TO THE O/S FRONT AND N/S REAR
ANYONE ANY IDEAS
Old Aug 29, 2006 | 10:26 AM
SafeChav's Avatar
SafeChav
Seals gone on one of the cylinders inside the master cylinder, or you're very unfortunate and both brakes on that particular line have seized (not a chance IMO)
Old Aug 29, 2006 | 10:39 AM
PeteS2RST's Avatar
PeteS2RST
are repiar kits still availible or best to buy new
Old Aug 29, 2006 | 11:28 AM
SafeChav's Avatar
SafeChav
I'm not sure if seal kits are still available? To be honest a failed Master Cylinder on a MK4 is a rare occurence.
Check out both of the respective brakes first just incase you they have both seized, its slim chances but worth a check first
Old Aug 29, 2006 | 10:04 PM
bigmatt-s2rst's Avatar
bigmatt-s2rst
all packaged up and ready for posting mate
JK12
33
Apr 26, 2021 12:09 PM
Rsmat
63
Sep 25, 2015 12:11 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
