blue smoke when hot and at idle?
Old Aug 19, 2004 | 09:13 PM
M Brian's Avatar
M Brian
Default blue smoke when hot and at idle?
on a FRST - what is the most likely cause?
car has apparently being standing for a while...
guy said it was stem seals, But i woulda thought this was more cold when starting rather than running.
Old Aug 19, 2004 | 09:24 PM
Physio's Avatar
Physio
It does sound like the stem seals, it would also smoke when hot.
Old Aug 19, 2004 | 09:28 PM
Neil S's Avatar
Neil S
Stem seals can give a big puff when starting first thing, and also at idle when there is enough vacum to pull the oil thru the seals
They're only shrapnel each, make sure you get the new 'top hat' shaped ones as they cant come loose
SP do a tool to let you change them without taking the head off - buy one from helfords, then clean it up and take it back for a refund when yer done
AND DONT DROP ANY COLLETS DOWN INTO THE SUMP!!!!!
Neil.
Old Aug 19, 2004 | 09:36 PM
RobS's Avatar
RobS
i had that on mine m8 turned out 2 be turbo
Old Aug 19, 2004 | 09:54 PM
Wazzzer's Avatar
Wazzzer
For £15 its worth doing the stem seals just to see if it is them, but it does sound like the turbos expired....
Old Aug 19, 2004 | 10:49 PM
M Brian's Avatar
M Brian
well i aint bought it im contemplating it.... and the guy has described the problem above.
Old Aug 19, 2004 | 10:53 PM
Lee Reynolds's Avatar
Lee Reynolds
Neil.
Ahhhhh. I now feel content as im not the only dipstick to do that before PMSL
RSTurboPaul's Avatar
RSTurboPaul
If you go out for a run in it then you can see if it smokes on the over-run - classic dead turbo sign. (IIRC!)
Old Aug 19, 2004 | 10:58 PM
RSrussell's Avatar
RSrussell
but yours smoked on boost too
Old Aug 19, 2004 | 11:29 PM
Azrael's Avatar
Azrael
My Escos smokes at idle only - I've already started a thread on that. We still have no idea why but the turbo is most likely reason.
Old Aug 20, 2004 | 12:00 AM
M Brian's Avatar
M Brian
yah i noticed your thread about 5 mins after i put this up
soem good info on there... although worrying info!! lol
ill have a look and if rest of car is ok see what i can bring it down to.
dont want big bills if only just bought it.
Old Aug 20, 2004 | 01:14 AM
Rick's Avatar
Rick
tuebo
Old Aug 20, 2004 | 01:26 AM
Azrael's Avatar
Azrael
Maybe you schould try what I'm going to do - unbolt the turbo from the manifold and check if smoke comes from turbo or the engine...
Old Aug 20, 2004 | 01:32 AM
M Brian's Avatar
M Brian
ah may do.. but its a car im thinking about buying (ive not been to see it yet, it may be gone tomorrow for all i know now!)
also its a cvh head on it so its pretty straight forward and cheap to change stem seals so mayaswell do that first off
Old Aug 20, 2004 | 02:06 AM
Rick's Avatar
Rick
Melv - i heard u get hot and idle whenever u see a CVH in a mk2...
Old Aug 20, 2004 | 08:26 AM
RS_Rawli's Avatar
RS_Rawli
Neil.
i dropped the last one down was fcuking gutted, managed to fish it out with a magnet though
Old Aug 20, 2004 | 08:43 AM
M Brian's Avatar
M Brian
ROTFLMAO!!! barsteward!!!!
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
