Fuck sake, car stalled today and would not start.
Old Aug 25, 2006 | 11:53 AM
Terry Tibbs's Avatar
Terry Tibbs
Default Fuck sake, car stalled today and would not start.
There I was, happily plodding along, and the thing dies on me, fire it up again, 3 seconds, stalls..
What the hell I think?
Push it up out of the road and go to take a look, expecting something minor.
Get under the bonnet.. nothing, everything looks fine.
Fuel pump isn't priming.. why? Anyway, ordered a new relay in the end hoping its that. if not it could be the pump.. but dunno..
Plugs, leads and coilpack are fine..
Old Aug 25, 2006 | 01:53 PM
BRAMMER's Avatar
BRAMMER
Shit petrol maybe, this type of thing happend to mine in july, car just cut out popped bonnet nothing everything how it should be, kept trying to fire, nothing.... i thought the worst just before i was on full boost, thought i'd melted it but then it fired up and ran a dream, remembered i put tesco fuel in instead of the norm shell.
Old Aug 25, 2006 | 02:42 PM
Ken_ZS's Avatar
Ken_ZS
does the fiesta have a odd positioned fuel pump relay like the escorts have? might be loose or knackered! or if u have a fuel cut off like my Zetec S it might be triggering or faulty!
Old Aug 25, 2006 | 03:36 PM
jayRS's Avatar
jayRS
prob the green relay, maybe a fues to the pump has blown.
somethims the cut off switch plays up, although it could still be on it may of gone dry, ive come across it on a few fords ive worked on, just a case of pull the switch up, push it down back into on postion, do that a few times to make sure.
its located behind the passange kick trim under the dash.
or could be that your out of fuel? maybe the sender isnt working right?
i would also check the plug on the tank, give it a little spray with some WD40.
Old Aug 25, 2006 | 04:30 PM
Oranoco's Avatar
Oranoco
Whip your back seat up and remove the wiring plug to th epump and see if it's getting voltage. If not remove the passenger side kick plate and bypass the inertia switch and see if you then get a reading. If you don't start looking at the relays if you do then you need to sort a new one out.
Turned out to be this on my brothers FRST a few weeks ago.
Old Aug 25, 2006 | 04:33 PM
jayRS's Avatar
jayRS
i got a spare cut off switch if it turns out to be that
Old Aug 26, 2006 | 04:55 PM
Terry Tibbs
Just changed the fuel pump relay but the battery is flat and cant get to it til tomorrow..
Going to try all of the above.
Old Aug 26, 2006 | 05:07 PM
kjc300's Avatar
kjc300
could be the rubber seal on the fuel pump gone as well, my old one would start and then die straight away. And thats what it was!!
Old Aug 26, 2006 | 09:43 PM
gar mae's Avatar
gar mae
Alternator?
Old Aug 27, 2006 | 05:23 PM
Terry Tibbs
Bad earth? since when have fiesta's had a main engine earth in the boot?
Old Aug 27, 2006 | 06:16 PM
gar mae's Avatar
gar mae
Nobody mentioned a bad earth, all I said was alternator, as in the alternator is shagged possible, cos it cut out, wouldnt start back and your battery is dead.
Plus you be having probs with the fuel pump not priming
Old Aug 27, 2006 | 06:46 PM
Terry Tibbs
Sorry meant I had found the source, a bad earth in the boot, connecting to the rear panel.
Old Aug 28, 2006 | 09:46 AM
gar mae's Avatar
gar mae
Ahhh!!
Good job
Fordmad!
Sep 26, 2015 05:24 PM
xr_craig
Aug 7, 2015 06:00 PM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
