MISFIREING S2 HELP PLEASE
Old Aug 24, 2006 | 08:49 PM
kirky's Avatar
kirky
Default MISFIREING S2 HELP PLEASE
My mate has just had his head gasket done by his mate it has been skimmed and pressure tested, new valves and a kent fast road cam kit put in! its timed up correctly,new plugs,rotor arm and dizzy cap theres compression,sparkand fuel getting through but its missing like theres a plug out but not as severe as a plug out!
theres no air leaks or from what i can see from pipes or gaskets
cant think of anything else to look at but thaught someone may have had this problem! HELP PLEASE!
Old Aug 24, 2006 | 10:09 PM
Noisy Boy's Avatar
Noisy Boy
didnt think you was surpose to skim heads on turbos but i could be wrong?
Old Aug 24, 2006 | 11:34 PM
scotty86d's Avatar
scotty86d
if you take a small amount like 7 thou off its fine.
Old Aug 25, 2006 | 01:21 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Are the plug leads round the right way?
Old Aug 25, 2006 | 05:31 PM
kirky's Avatar
kirky
yea m8 all the plug leads are fine n still cant find the problem!
Old Aug 25, 2006 | 06:08 PM
HORNETS7's Avatar
HORNETS7
THIS PIC MIGHT HELP!!!!!
http://img.photobucket.com/albums/v2...IRINGORDER.bmp
Old Aug 25, 2006 | 07:08 PM
jamie rst's Avatar
jamie rst
Hi mate,
I had a misfire on my turbo after fitting a new head gasket and a new cam mine is a piper one, i was timing it up using the new pully that come with the cam kit, my misfire turned out to be that the top dead centre point on the cam pully is not top dead centre i took the 19mm bolt out of the cam and found that the woodruf key was facing down towards the bottom end and this is wrong the woodruf key should face up towards the bonnet as the woodruf key is the ture top dead centre coulb be worth have a look mate
Old Aug 27, 2006 | 11:14 AM
kirky's Avatar
kirky
Originally Posted by jamie rst
Hi mate,
will check this out m8 when i get chance and let u know!
Old Sep 11, 2006 | 06:10 PM
kirky's Avatar
kirky
found out what the misfire was!!!!! Took the new cam back out and on inspection the lobe on exhaust valve on no. 4 piston was rounded instead of being lobe shape! this seems to me to have been like this from new as it was missfireing from the first turn of the key! so has anyone had a faulty cam from kent?
j.hammond1
30
Oct 31, 2021 05:28 PM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
taylora1409
Aug 12, 2015 12:06 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
