My car is being a freak - solved!
Old Aug 21, 2006 | 02:39 PM
Drewman's Avatar
Drewman
Default My car is being a freak - solved!
I stupidly left my lights on while i was at work....
first time i've ever done that!
and of course the battery died....so i jump started it and took it for a drive during my break...about 20mins, so i got back and worked some more...came back to my car and it started....
only problem being is....the stereo, clock, central locking, cig lighter doesn't work, which i find strange, seeing as it starts
is this normal or has something broken??
Old Aug 21, 2006 | 02:45 PM
SapphyMike's Avatar
SapphyMike
check fuses.
Old Aug 21, 2006 | 02:46 PM
ballin's Avatar
ballin
do they work when the engine is running?
what about the lights, are the really dim?
clock should work, the others may take quite a drain so possibly they might not until its changed up again dunno really
Old Aug 21, 2006 | 02:47 PM
MAD EVO 4's Avatar
MAD EVO 4
As said check fuese some may of blown when charging or jump starting your car
Old Aug 21, 2006 | 02:58 PM
Drewman's Avatar
Drewman
ok will do, yeah when engines running.....
lights work fine too
Old Aug 21, 2006 | 03:03 PM
Drewman's Avatar
Drewman
confirmed
blown fuse...theres one which controls all the items which aren't working
cheers
Old Aug 21, 2006 | 03:04 PM
SapphyMike's Avatar
SapphyMike
Shows & Track Days
Aug 26, 2015 05:11 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
nick8saff
Aug 16, 2015 05:35 PM
