quick question about saff fuel pumps
Old Aug 20, 2006 | 06:54 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Default quick question about saff fuel pumps
can i run a standard saff cos tank and mount my fuel pumps and filters in the spare wheel well or will they need to be below the tank for gravity feeds?
cheers folks
Old Aug 20, 2006 | 10:58 PM
capri-rs's Avatar
capri-rs
you will need a swirl pot and a lift pump for that.
why not use a big pump mounted where the standard pump is like MADrod have done
cheers
Old Aug 20, 2006 | 11:20 PM
Kevin Sharp's Avatar
Kevin Sharp
if you have an engine running the power you have claimed in the past you should know this already
Anutternutter
24
Aug 31, 2015 01:24 PM
ekjim
Aug 27, 2015 05:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
