FFS! Think ive blown my gearbox!
Was accelerating hard when all of a sudden the box started making a rite noise
Now it makes the noise in pretty much every gear(But the noisiest is 3rd)
And it even makes it in neautral when the clutch is released
Ive only had the box in 2 months( only used the car 3 times)
Jon, If it's a loud knocking noise, could be the chain in the transfer box.
Sounds like it's stretched enough (under hard acceleration), so that it is now skiping the driven tooth wheel. It can do this in neutral with clutch down......DONT ask me how I know
Cheers for the advice lads
The car is selecting gear fine but its making a racket
The gearbox is a Swedish Fixit kit with a centre push bearing and twinplate clutch
Hi Doug was yours the red escos i saw today tearing up donno( and rainbird by the look of it)
Would the diff still make a racket if the car was stood though doug?
Are these part of the box doug?
Think i should change my name to unlucky Alf
best thing you could do john is do what we were talking about today. 2wd it .praps i sould,nt of asked you how the box was today. but you did say it was fine . sorry to here you have brock it tho m8
Cheers Lads im well gutted
The box was only fitted 2 months ago now ive gotta take it out again and send it away
Yeh Kev i think i saw a couple of Fiesta turbos travelling just behind me
Jon,
As per my PM, keep me posted as to what broke, and I'll get Bjorn to sort it (if it is a Fixit part that has broken). Fingers crossed it isn't the main shaft, as that is still the Ford part
I also thought it sounded like the chain drive from your description, but now it's sounding like it is a chipped tooth on the input shaft...
.I also thought it sounded like the chain drive from your description, but now it's sounding like it is a chipped tooth on the input shaft...
chowfornow
14
Jan 5, 2019 09:01 PM
