no bosst on sierra cossie???? anyonew help please guys
Old Aug 19, 2006 | 11:57 AM
cossiekillers's Avatar
cossiekillers
Default no bosst on sierra cossie???? anyonew help please guys
Could someone please help,i hava a k plate saph with no boost whatsoeverShe seemed to gradually lose the boost over a couple of mths,in the end with the actuator wound up she was struggling to hit 9psi,and would drop off to as low as 6psi.I have changed the Turbo/wastegate,new Samco hoses,put a live to the Amal valve to check if it clicked-it did.Oh the Actuator is new also,temp sensor has been replaced,charge-air sensor,belt timing has been checked,I have been enquiring after a map sensor,and hopefully will get one for next week. I really am running out of ideas,so if anyone could help me in my hour of need,i would be greatfull with any suggestions.thanx
Old Aug 19, 2006 | 12:01 PM
kjc300's Avatar
kjc300
Dump valve??? if you have one - diaphragm might be split??
Old Aug 19, 2006 | 12:07 PM
cossiekillers
its a new balieys one but itll get checkd today
wastegates bin changed turbos turning fine??
Old Aug 19, 2006 | 12:50 PM
kjc300's Avatar
kjc300
Well a bailey one wont have a split diaphragm so that bits sorted!! Other than having a split or hole in the circuit somewhere (hoses, intercooler etc). You could try setting the actuator rod length so that with the wastegate closed you can see half the diameter of the spigot through the rod loop if you get what I mean. and then bypass the amal valve by looping the pipe from the turbo compressor housing, straight to the actuator.
Old Aug 19, 2006 | 01:33 PM
cossiekillers
ok ill check that buddy nice one thank you
Old Aug 23, 2006 | 06:38 PM
polred28's Avatar
polred28
boost sorted,blocked exhaust for the last two years.Full mongoose fitted and what a punch she has now!
c20tbo
Aug 17, 2015 10:19 PM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
knight19770
Aug 4, 2015 12:36 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
