actuator type please
Old Aug 18, 2006 | 09:26 PM
Neil's Avatar
Neil
Default actuator type please
can anyone identify the actuator on the cossie turbo for me please
Old Aug 18, 2006 | 09:28 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Looks like a Collins one...?
Old Aug 18, 2006 | 09:31 PM
Jasesapphy's Avatar
Jasesapphy
I would go collins deffo not a forge
Neil's Avatar
Neil
at moment it's running 19psi , aiming for 25psi got 1 complate hole of preload on it, using bleed valve to get to 19psi
Old Aug 18, 2006 | 09:33 PM
Neil's Avatar
Neil
here is another pic from the front
Old Aug 18, 2006 | 09:35 PM
Jasesapphy's Avatar
Jasesapphy
Easy tiger, no more head gaskets.
Neil was that C/R you have 7.8:1 or Higher, belive it or not still running 12-13 psi at 10.5:1
Old Aug 18, 2006 | 09:37 PM
Neil's Avatar
Neil
running 7:1
had engine running on old turbo before shaft went 1 night with boost pressures in excess of 30psi due to hose bursting at actuator
by heck it flipping shifted
Old Aug 18, 2006 | 11:40 PM
Doug's Avatar
Doug
Neil its a Collins race type actuator and only has a preload of 10 psi either change the spring or get another one .................
Regards Doug .
Old Aug 19, 2006 | 05:02 AM
Neil's Avatar
Neil
what other springs are available, collins engineering i take i have to phone then
Old Aug 19, 2006 | 06:56 AM
Jasesapphy's Avatar
Jasesapphy
They do abour 4 different springs IIRC
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Si B
Sep 12, 2015 06:49 AM
